New exhaust - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 04-27-2012, 05:31 PM Thread Starter
waving New exhaust
Just got a new exhaust, and noticed a carbon buildup on the tip of the exhaust. Do i need to adjust the fuel pump and if so how?
Its an fmf slip-on.
Much help would be appreciated!
mmarine2 is offline
post #2 of 9 Old 04-27-2012, 05:53 PM
700xxchris's Avatar
did u get a fuel programmer
700xxchris is offline
post #3 of 9 Old 04-27-2012, 08:30 PM Thread Starter
the whole bike is stock except the slip on
mmarine2 is offline
post #4 of 9 Old 04-27-2012, 11:33 PM
700xxchris's Avatar
get a programmer from ehs they will help u set it up our bikes run lean from factory anyway and that slip-on will just make it worse
post #5 of 9 Old 04-28-2012, 08:18 AM Thread Starter
Ok thanks man
mmarine2 is offline
post #6 of 9 Old 05-08-2012, 04:20 PM Thread Starter
Can you adjust the fuel pump instead of getting a fuel programmer
mmarine2 is offline
post #7 of 9 Old 05-08-2012, 06:24 PM
its EFI so I'd say no, unless you have a program to hook up to the ecu. The EHS programmer will take care of the settings and most future modifications as well.
post #8 of 9 Old 05-11-2012, 12:32 PM Thread Starter
i put the stock pipe back on, its running strong now and no more carbon buildup. This summer im going to buy the programmer and put the exhaust back on. Thanks guys!
mmarine2 is offline
post #9 of 9 Old 05-12-2012, 12:19 PM
Just curious... Did you ever look at the spark plug to see if there was carbon build up there? Checking the fuel mixture with a new plug is always going to be the best way to check if you're running lean or rich.
Tags
exhaust
