Clutch Issues? - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 04-30-2012, 09:56 PM Thread Starter
Clutch Issues?
Alright been having a high pitched whine coming from the clutch side of the engine for a while now. Tore it down the other day and found that the outer basket had some issues. The gear on the back side of the outer had about 3 to 5 thousandths play. Thinking this was the problem, I bought a new basket and just installed it. The bike is still making the same noise. The noise increases with throttle and it does it all the time , whether it's in gear or in in neutral and you can hardly hear it when idling. Once you hit the gas though it is very loud. Does anyone have any thoughts as to what could be making this noise?
post #2 of 8 Old 04-30-2012, 11:57 PM
DL700's Avatar
so if your in say 1st gear with the clutch pulled in it makes the noise still?
DL700 is offline
post #3 of 8 Old 05-01-2012, 08:37 AM Thread Starter
Yes still makes the noise
post #4 of 8 Old 05-01-2012, 12:46 PM
DL700's Avatar
well if it makes the noise when in gear and the clutch pulled and while in neutral with the clutch lever released they it sounds like its engine related
DL700 is offline
post #5 of 8 Old 05-01-2012, 12:50 PM
DL700's Avatar
check the throwout bearing
DL700 is offline
post #6 of 8 Old 05-01-2012, 02:20 PM Thread Starter
You talking about the small thin bearing that rides inside the clutch hub right?
post #7 of 8 Old 05-01-2012, 07:40 PM Thread Starter
Put a stethoscope on various parts of the engine and found that the noise is coming from directly behind the clutch cover. DL I think it is as you suggested the little throw out bearin has gone bad. Gona try to find a replacement
post #8 of 8 Old 05-02-2012, 12:40 AM
DL700's Avatar
replace the hard washers as well
DL700 is offline
