Air box - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 05-11-2012, 01:25 PM Thread Starter
Air box
I bought a 700xx, the guy decides to cut the top of the air box open for more air to pass through, when revving the gas it boggs out a little bit. I was wondering if this is due to too much air coming through and was wondering if i should get another lid ? Its all stock. Much help would be appreciated!
mmarine2 is offline
post #2 of 11 Old 05-11-2012, 05:05 PM
That wont cause the bog problem. I would cover and seal the hole, or put Outerwear over it. To much dirt will get in and require premature filter cleaning.
Mav
'08 XX *Sold*
13T, Alba Nerfs, DS450 shocks
MadMav is offline
post #3 of 11 Old 05-11-2012, 08:19 PM
Quoted: 252 Post(s)
If you have the cash get the EHS lid.
http://www.ehsracing.com/products/tr...airbox_EHS.htm
post #4 of 11 Old 05-11-2012, 10:23 PM
boost addict's Avatar
I made my own for 13.00 $
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #5 of 11 Old 05-12-2012, 08:51 AM Thread Starter
Any idea what would be causing the bog issue
mmarine2 is offline
post #6 of 11 Old 05-12-2012, 09:09 AM
What air filter are you using? Has it been cleaned recently? Removing the lid or opening it up should make it run better not worse.
Ed @
Chris & Mike
post #7 of 11 Old 05-17-2012, 07:06 PM Thread Starter
Its a uni filter
mmarine2 is offline
post #8 of 11 Old 05-18-2012, 08:35 PM
Clogged fuel filter or injector maybe.
post #9 of 11 Old 05-18-2012, 10:28 PM
Quoted: 252 Post(s)
plug check?
post #10 of 11 Old 05-28-2012, 11:47 PM Thread Starter
the things legit brand new with about 50 hours . it might just be a fouled spark plug. any idea on how to get the spark plug off? thanks guys
mmarine2 is offline
