Fuel Controller - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 05-21-2012, 06:59 PM Thread Starter
Question Fuel Controller
So i want to get an efi controller but i dont know which one, how to use it or install it, they look so complicated with all the maps and stuff, how do i know what to tune it for and how do you tune it for your own mods. Can i do it myself??
xxdanxx is offline
post #2 of 7 Old 05-21-2012, 07:21 PM
700xxchris's Avatar
depends on what you have done most of what you will need one for the ehs programmer is the one just about everyone goes for on here and from what i heard eric at ehs has great customer service and will help with whatever needed
700xxchris is offline
post #3 of 7 Old 05-21-2012, 07:26 PM
First what do you plan on doing both now and future to your engine? That will let us know more of what you should get. As far as mapping and tuning that can start to get more difficult. Eric at EHS has settings for his controller for a few different setups that can be really easy to do. Power Commander has some too. You can do most the tuning on your own via settings or pre-made maps depending on which route you end up going. Those will get you pretty close and good enough to run. Now if you are going big then you will want to end up going to a dyno to get a personalized tune for the best performance.
post #4 of 7 Old 05-21-2012, 09:17 PM Thread Starter
im not going to do any internal mods just a full exhaust, air filter and a lid for now so i might just grab to ehs package
xxdanxx is offline
post #5 of 7 Old 05-21-2012, 10:57 PM
If thats all u plan to do, then the EHS package will work fine for you.
08 Honda 700xx
Installed
Britalican is offline
post #6 of 7 Old 05-21-2012, 11:04 PM
Yep you should be good with the EHS package. Easy to set up and use. Also if you need help Eric provides great customer service!
post #7 of 7 Old 05-22-2012, 11:28 AM
I agree with the others... the EHS efi controller is top notch. Don't sweat the install... super easy and quick. Also changing settings is quick and easy once you do it once or twice. I can start a ride up a mountain and when we all stop to take a break about half way up, change my settings for the higher altitude in about 5 minutes... OR to ride with the quiet core or without.
