Barkers Exhaust Question - Club700XX - Honda TRX700XX Forum
post #1 of 17 Old 05-24-2012, 07:32 AM Thread Starter
Should this pipe be against the engine? I would have thought it would have some clearance in there. You can't slide a sheet of paper through it. I think it will be ok if it IS supposed to be against it, but I'm just checking with you guys as I didn't get any instructions (not that you have to be a rocket scientist) to put it together.
post #2 of 17 Old 05-24-2012, 07:39 AM
I have measurements floating around on the forum some place but there needs to be a gap there not much of one but something. The usual reason its tight there is because the can is generally not installed far enough into the billet bracket which pushes it closer to the cases.
as you push the can further into the clamp you will want the head studs loose the further you raise the head pipe up towards the seat the more clearence you will get where you need it as well.
just loosen the stuff up and play with it you will get it. I put a big screwdriver or a open end wrench in the billet clamp to keep it open so when your moving it around it doesnt scratch the can. this allows you to position everything easier if its a little bit off the extra room dries up quickly
EHSRACING is offline
post #3 of 17 Old 05-24-2012, 07:44 AM Thread Starter
I'll try to do that today, yeah and a light application of Mothers mag/aluminum polish will get those scratches off ;) It's almost impossible to get that clamp on without scratching it.
post #4 of 17 Old 05-24-2012, 12:30 PM
just gotta adjust your muffler. I did that and it had a slight clearance but once it warms up it still rub.
post #5 of 17 Old 05-24-2012, 07:39 PM
thats worse than the old design. mine rubbed in the twelve clock pos andyours lookar the s like the 10 clock where yours is rubbing. thats bs. i probaly will never buy another barker for my xx . they told me to take an arbor press and bend the header to clear the case. should of fit right first time ill probally go with a duncan or sparks, wish trinity made one they have a killer new packing system for repacks
post #6 of 17 Old 05-24-2012, 09:31 PM
Quoted: 5 Post(s)
Wow an it cost you how much what ever happen to customer service?????
Elmer is offline
post #7 of 17 Old 05-24-2012, 10:17 PM
Unfortunately adjusting the muffler won't help that. I would call and make them replace that!
post #8 of 17 Old 05-25-2012, 12:25 AM Thread Starter
Man, now you guys have me kind of scared. I've only fired this up for 5 seconds, haven't even rode it... it hasn't even burned the oil off my hands off of it and you have me wondering. I wondered about that connection because where the pipe was expanded for the head pipe to slip in, was WAY off to one side. I kinda said WTF when I saw it, but I just kept on. I was able to put about 1/4" on the gap tonight. Here are new pics. Nothing a crow bar can't fix! I would contemplate sending it back, but I have a big trip i'm leaving for - in 12 hours... I can't take everything off now.
post #9 of 17 Old 05-25-2012, 12:31 AM Thread Starter
Here's the best pic I currently have of that expansion connection joint.
A. you can see is a smooth transition on the back side.
B. There's a HUUUUGE hump in the pipe where the expander pushed way out to one side.
post #10 of 17 Old 05-25-2012, 05:55 AM
Wow looks like you scratched the piss out of your case trying to get clearance!
HMF Header below...
