Anyone had this problem? - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 06-02-2012, 01:18 AM Thread Starter
I have a FMF fuel programmer,FMF Q pipe and K&N filter. I was riding in the Oregon dunes. While climbing some steep dunes my XX it would sputter out and die 3/4 of the way up. It died twice while climbing steep dunes and then was fine for the rest of the afternoon. It starts right back up after it dies and the power seems fine. I'm just wondering if my programmer is on it's way out? At idle my programmer seems to bounce between 3 lights lit and 1 light lit. Can anyone with an FMF programmer tell me if theirs does the same. Thanks
trx700xx69 is offline
post #2 of 12 Old 06-02-2012, 01:20 AM
700xxchris's Avatar
sound like the tilt/flip sensor
700xxchris is offline
post #3 of 12 Old 06-02-2012, 01:26 AM Thread Starter
Thanks
Thanks 700xxchris, I will have to look that one up in the maintenance manual.
post #4 of 12 Old 06-02-2012, 11:21 AM
I'm not so sure that it's your bank angle sensor. Generally, this trips if you roll over, not from going up a steep dune. Going up steep things (dunes, hills) is something that quads regularly do and any sensor should not trip unless you get to a point of no return. If I remember correctly, that sensor is either tripped or not and once tripped, you need to right the quad, turn the key off, wait a couple seconds for the sensor to reset, turn the key back to on start the quad and go.
This happened a couple races ago with a friend on her 700xx... she rolled over on an off camber turn but could not get her quad to start again when back on her wheels. I came over, turned her key off and turned it back on after 2-3 seconds. Her quad started right back up. She didn't know about the bank angle sensor.
post #5 of 12 Old 06-02-2012, 03:42 PM
700xxx's Avatar
I have had mine do the same thing, the angle sensor will shut it down if you get it standing on the rear bar. I have the fmf full exhaust factory 4.1 k&n and fmf tuner. ha ha also at the dunes in florance
700xxx is offline
post #6 of 12 Old 06-02-2012, 07:25 PM
DL700's Avatar
i have an extra rollover switch here... maybe ill cut it open and find a good way to fix it in location
DL700 is offline
post #7 of 12 Old 06-02-2012, 09:04 PM
MizuriDirt's Avatar
Sounds more like a fuel pick up problem to me.
08 TRX700XX(red)
HMF Pipe and Muffler
HMF Programmer(Custom Tuned)
EHS Lid
13T Driver
Maxxis Razr2's front, Razrs rear
Fasst Flexx 15degree Quad Bars
Trail Tech Riser
ASV F3 Levers
ODI Rogue Loc-ons
Fox Floats front
Podium-x rears(coming soon)
PRM Desert II front bumper
PRM nerfs
PRM standard grab bar
Quad-Tech Seat
Teixeira Tech CNC Upper A-Arms
MizuriDirt is offline
post #8 of 12 Old 06-03-2012, 12:46 AM Thread Starter
Thanks
Thanks for all the info everyone. I was out on the XX today and it seemed to run fine. It did stall once at idle when i hit the throttle quickly.
post #9 of 12 Old 06-03-2012, 06:14 AM
There is a way to bypass the rollover switch. I removed mine to put the regulater/rectifier in its place to fit the steering dampner.
I was wondering how much fuel you had in the tank when it cut out. The fuel tap is at the front of the tank. You always try it on reserve if it does it again on the steep climbs.
post #10 of 12 Old 06-04-2012, 07:54 PM
that was my first thought too.
I ride the oregon dunes all the time, and have never had this issue though.
08 Honda 700xx
Installed
Britalican is offline
