Decompressioner - spring? - Club700XX - Honda TRX700XX Forum
post #1 of 2 Old 06-11-2012, 10:13 AM Thread Starter
I swore the decompressioner had a spring on it, but when I took it off the stock cam to put on the Hot Cam, there wasn't a spring. We put it on anyway and I haven't noticed anything wrong with it or any weird noises either. I'm sure if a spring is supposed to be there it makes it work correctly. What's the worst that can happen without a spring? Would it just not work? I saw this picture on ebay and it made me wonder about it though.
post #2 of 2 Old 06-12-2012, 04:19 AM
yes there is a spring, and it tends to go flying when u pop the decomp off. took me 10 min to find mine the first time i did it. im sure its there for a reason, so i wouldnt run without it. dont you have 2 stock cams? get the spring off the other one, or go buy a comparable spring.
08 Honda 700xx
Installed
Britalican is offline
