What Octane for EHS controller with Big3 + HC3 Cam? - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 07-03-2012, 01:52 PM Thread Starter
What octane gas are these for? I run 93 octane reguarly. I might be a little rich... Would it be ok to lean it up some?
post #2 of 15 Old 07-05-2012, 02:53 PM
MizuriDirt's Avatar
I think it would be a matter of if you need to change plug #'s. Maybe I'm wrong though. Either way it looks like your running rich. Was that after running it around for a bit? Was it a new plug to start with after your build? Higher octane fuel burns slower so if anything it would be running a little cooler cyl temps if I'm not mistaken. Get ahold of Eric if thats who's stuff your using. He will set you straight I'm sure.
08 TRX700XX(red)
HMF Pipe and Muffler
HMF Programmer(Custom Tuned)
EHS Lid
13T Driver
Maxxis Razr2's front, Razrs rear
Fasst Flexx 15degree Quad Bars
Trail Tech Riser
ASV F3 Levers
ODI Rogue Loc-ons
Fox Floats front
Podium-x rears(coming soon)
PRM Desert II front bumper
PRM nerfs
PRM standard grab bar
Quad-Tech Seat
Teixeira Tech CNC Upper A-Arms
MizuriDirt is offline
post #3 of 15 Old 07-06-2012, 09:04 PM
scrawny's Avatar
cooler temps and less hp with stock compression ;)
08 700xx
05 Ruckus
04 450r
86 Fat Cat
86 350x
81 250r
72 CB100
scrawny is offline
post #4 of 15 Old 08-18-2012, 02:23 PM
High octane isn't required until you raise compression. The plug does look a bit rich though, Are you running the recommended programmer settings?
90HPXX is offline
post #5 of 15 Old 08-19-2012, 10:42 AM
Those dobeck programmers always run a little rich, you could get a hotter plug that may help
post #6 of 15 Old 08-19-2012, 12:08 PM
traitor08's Avatar
There is a sticker on my gas tank saying to run premium from factory.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #7 of 15 Old 08-20-2012, 08:05 AM
What year do you have, I've had a couple 08's and never seen the sticker. I'm not sure why they would suggest it though, 10:1 with an aluminum head wouldn't raise flags to me
90HPXX is offline
post #8 of 15 Old 08-20-2012, 04:31 PM
I have the same sticker as well
post #9 of 15 Old 08-20-2012, 05:03 PM
traitor08's Avatar
08, I bought new so I know its factory. It is above the gas cap if you are sitting on it. Between the cap and bars.
MY RIDES
post #10 of 15 Old 08-20-2012, 08:30 PM
Ba9801's Avatar
I also have that same sticker on my 08 that I bought new
Ba9801 is offline
