top end rattle - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 07-12-2012, 12:01 PM Thread Starter
Garrett22's Avatar
top end rattle
the top end of my 700 makes a rattling sound at different gears and idles. anyone else have the same problem or know the cause/fix?
08 700xx black & silver
-barkers exhaust
-alba programmer
-uni filter
Garrett22 is offline
post #2 of 12 Old 07-12-2012, 04:02 PM
Quoted: 252 Post(s)
check the valve clearance.
post #3 of 12 Old 07-15-2012, 10:39 PM
Bxxreal's Avatar
I had that problem it was a simple fix, check the two bolts on the head pipe heat guard. If not that could be valves. You could try holding a long screw driver handle up to your ear and place the tip on the head near the valve inspection caps with the motor running it will amplify the sound.
Bxxreal is offline
post #4 of 12 Old 07-16-2012, 07:09 PM
BuckeyeXX's Avatar
Agreed on the valves. If it gets louder as you accelerate then most likely its the valves. If it is then they are easy to adjust. But as stated above it could be as simple as something loose. Good luck
08 700XX Black/Gray
01 90 Yerf Dog
BuckeyeXX is offline
post #5 of 12 Old 07-16-2012, 11:18 PM Thread Starter
Garrett22's Avatar
i was thinking it was the valves but ive never messed with em before. what do i need to do to adjust them?
-barkers exhaust
-alba programmer
-uni filter
post #6 of 12 Old 07-16-2012, 11:53 PM
700xxchris's Avatar
service Manuel,metric tools,metric feeler gauges and some patience anyone chime in if i left anything out
700xxchris is offline
post #7 of 12 Old 07-17-2012, 03:17 PM
Quoted: 252 Post(s)
Plenty of cold ones, cause it's been hot...
post #8 of 12 Old 07-17-2012, 08:28 PM
700xxchris's Avatar
thank m quick i knew i was forgetting the most important part
post #9 of 12 Old 08-18-2012, 10:18 PM
I have the same problem. It only rattles while accelerating so im guessing its the heat guard,. I put my foot on it while i drive to test it out and the noise goes away. I tightened it but it still seems to come back every once in a while. Should i just take the heat guard off? much help would be appreciated. Thanks
mmarine2 is offline
post #10 of 12 Old 08-19-2012, 09:22 AM
Quoted: 5 Post(s)
I had a similar issue when I bought my 700. At first the heat shield rattled but it kept coming back as I continued working on it and just running/revving letting it idle. When I looked into the parts that were missing on mine in the exhaust picture there is an exhaust gasket between the muffler and head pipe. I bought, went to replace it and the old one was paper thin, barely even noticeable it was so thin and the new one was a BIOTCH to get on but the rattle is all gone.
I had to pry the opening on the muffler open more in order for it to fit on and then clamped the muffler opening to put it closer back to the size it was prior to prying it open.
http://www.powersportsplus.com/parts...LER/parts.html
#11 - Part# 18392-MK4-000
Hope that helps at least I know it fixed my rattling noise.
Dan
2008 Honda Trx700xx
2007 Yamaha Wolverine 450 4x4
2009 Raptor 90
2005 Polaris 50
Snowdog is offline
