Anyone ever separate a 700 motor case ?? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 07-12-2012, 07:08 PM Thread Starter
I mite have to separate the motor case on a 700 to look for/clean out any debris from a piston disaster, so dont know what its gonna take to complete the job.
Question: has anyone on here done this before ??
If so...how hard is it to do??
Any specialty tools needed ??
Thanx
Johnny Reb is offline
post #2 of 6 Old 07-12-2012, 11:14 PM
It is very tedious and labor intensive. There are lots of pieces and parts especially in the transmission. You will need a couple of special tools to split the case. Its really not difficult just a pain. Get yourself a service manual and a bunch of ziploc sandwich bags and label all the parts. My buddy made a tool to seperate his case for the 700xx and i dont know if you can buy one specific for this particular model.
post #3 of 6 Old 07-13-2012, 06:51 PM Thread Starter
Thanx for the advice, realy not sure it needs taken apart yet, but I dont like the possability of bits & pieces of metal float'n around inside the motor.
Been think'n of a way to test the waters before tear'n into it, maybe flush it out a time ot two with some fluid/oil & see if anything empties out along with the fluid.
I also have a XR650R that needs the case split so I can put a new crank in it, maybe the same case seperater will do for both machines.
post #4 of 6 Old 08-05-2012, 07:52 PM
You only need special tools if you have to remove the crank. If you only want to split the cases then no tools are needed but just use common sense. I have split both motors and the only special tool I used was a flywheel puller and a Motion Pro clutch ,vise grip thingy.
post #5 of 6 Old 08-10-2012, 08:45 AM
Simplyorange's Avatar
its not hard, these 2 tools is all you need, i actually bought a bolt for the flywheel instead of a puller and it worked perfect with a little grease on the end.and it only cost me $8. just use cardboard to keep track of where your bolts go, i did mine over a weekend.
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #6 of 6 Old 08-10-2012, 03:20 PM
DL700's Avatar
Clutch tool isnt needed but nice to have,,, just use an impact(small) and a leather gloove to hold the inner hub, rag works too
DL700 is offline
