better 5th gear? - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 07-22-2012, 11:59 PM Thread Starter
XxX700XxX's Avatar
better 5th gear?
My 5th gear is kinda slugish when im drag racing.so when people do pass me up its in 5th gear.what can i do to fix this? I just want my 5th gear to pull hard like 4th.maybe i have to much paddle? 22 11 10 8 paddle haulers maybe a 7 paddle would help?? Or 15t sproket? Or maybe a 13t sproket idk? Any help would be great.
2009 700xx
1989 yamaha banshee
not stock
80hp
XxX700XxX is offline
post #2 of 9 Old 07-23-2012, 07:50 AM
traitor08's Avatar
13t sprocket, or nitrous LOL
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #3 of 9 Old 07-23-2012, 08:33 AM
Nitrous or build it..
Jakes700xx is offline
post #4 of 9 Old 07-23-2012, 01:03 PM
A 13t sprocket will give you lower gearing in ALL gears, you'll be able to pull harder in 5th, but you'll also be going slower. A 15t will give you higher gearing in ALL gears. You'll be going faster in 5th, but you won't be pulling hard.
The only way to really improve pulling in 5th gear without being slower would be to improve power.
post #5 of 9 Old 07-29-2012, 02:51 PM
15tooth sprocket and stay in 4th
post #6 of 9 Old 07-29-2012, 10:12 PM
more power, I thought I read that a cam and 11 to 1 piston will give you 2 or 3 more horse.
500Rubie is offline
post #7 of 9 Old 08-17-2012, 07:32 PM
I have no problem with my 700xx , no raptor 700r will pass me nider on a long ran or drag race but this is what i got; power comander, full exhaust,k&n filter,and thats all you need.
702cuellar is offline
post #8 of 9 Old 08-17-2012, 09:42 PM
Dune64's Avatar
thats what I would try, higher geared front sprocket but stay in lower gears longer. It should change the speeds your bike makes it's power at. For less than 20 bucks its worth a try.
I ran a 13t at some informal Glamis sand drags and found it was a little too low. I could keep up but it was hard to keep the front end down on starts even in 2nd. I wish I would have had my stock 14 on for the sand, next time I will.
just my $ .02 worth
08 700XX
07 Long Travel Rhino
07 Suzuki LT2550
06 Kido's Chino 70cc quad
04 Rancher 350ES
04 Rancher 350
91 Jeep YJ
81 ATC 70XX
Dune64 is offline
post #9 of 9 Old 08-17-2012, 10:51 PM
09RappySE's Avatar
Quoted: 16 Post(s)
Thats just too funny.....put down the bong, you better add a few more mods before you make that claim.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
