Programmer Questions - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 07-30-2012, 01:53 PM Thread Starter
I have the Motoworks SR4 slip-on and I am about to add a UNI filter. I don't need a programmer for this set-up do I? I am thinking that I don't.
Would a programmer even be beneficial with this set up?
Collie's700xx is offline
post #2 of 6 Old 07-30-2012, 05:00 PM
It would be beneficial but it is not needed
post #3 of 6 Old 07-30-2012, 08:35 PM
as above.
post #4 of 6 Old 07-30-2012, 08:48 PM
i have the same question i have the uni and want a slip on i think you do need a programmer because it will run to lean from what i hear and it gives more power but they look so complicated with all the mapping and stuff
xxdanxx is offline
post #5 of 6 Old 07-30-2012, 09:29 PM
Quoted: 252 Post(s)
Stock the quad runs lean, thus a programmer is not needed but most beneficial! I added my programmer before my exhaust and could tell a difference in the response from the quad.
M_Quick is online now
post #6 of 6 Old 07-31-2012, 11:57 AM
on a slip-on setup they will only pick up 1-1.5hp peak numbers with a tuned efi but the overall ride and feel of the quad was a good bit better imo
will you do damage without one not really with the lid off/ modified like ours they do lean out more and its more rec/neceassry then
will it run better yes
worth it, imo yes
EHSRACING is offline
