Help Carburator - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 04-19-2009, 02:45 PM Thread Starter
Help Carburator
OK! After 20 years of working around jet engine, you would think that I should be very proficient on bike engine but nooooooo! I'm replacing my throttle to a twist one and need to remove the carb since I do not have enough space between the frame and carb to remove the plastic cover. The problem that I have at this moment is how to disconnect the air hose, looks like an 02 sensor hose. Any help is greatly appreciated. Also beside the dealership, where can I purchase a manual.
Thank you.
post #2 of 7 Old 04-19-2009, 02:50 PM
If your 700xx has a carb, something is seriously wrong. I'm sure you are talking about the throttle body. You may find it easier to take the tank off and try from the top. You can find Honda service manuals on ebay for $20 or less.
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #3 of 7 Old 04-19-2009, 02:58 PM Thread Starter
Sorry, Ok! Throttle body, gas tank is remove but still can't figure out on how to disconnect the hose from it, it looks like a quick disconnect but not made for Dummies like me, lol! Thanks about ebay
post #4 of 7 Old 04-19-2009, 03:03 PM
Its easier to remove if you take the hose off with it that goes from the TB to the head. Loosen the worm gears then twist it to break the hoses free and pull out
post #5 of 7 Old 04-19-2009, 05:14 PM
Which twist throttle are you installing? Mine used the original cable and I just needed to disconnect it from the assembly on the bar.
08 700XX, FMF pipe, PC3, Velocity filter, OMF Beadlocks, PRM nerfs, bumpers and skids, Maxxis Razr's font and rear, Sonic anti-roll bar( BEST MOD AVAILABLE), Vapor dash, Pro-taper bars
01 Busa 500+ hp, carbon fiber rocket Velocity/Garrett powered, TotalKaos Built
08 B-king stock for now
Dave01 is offline
post #6 of 7 Old 04-19-2009, 05:18 PM Thread Starter
Purchase the Motion Pro which should be here sometime this week, ready for next weekend, hopefully
post #7 of 7 Old 04-19-2009, 06:29 PM
aschuck's Avatar
Dave01,
Which one do you have that uses the original cable?
Also is 1/4 or 1/2 turn.
aschuck is offline
