High RPM motor vibration/rattle issue - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 08-17-2012, 07:07 PM Thread Starter
easystreet's Avatar
So I have noticed in high rpm's this rattle that creates a lot of vibration. It definitely seems to be from the motor. It has gotten worse I believe. Gonna clean off the mud and remove some plastics and fuel tank to see if I have any loose motor mounts. Any ideas of anything else internal or external? I'm hoping I don't have a motor bearing going out.
easystreet is offline
post #2 of 9 Old 08-17-2012, 11:32 PM
CRAVEN7786's Avatar
Check your exhaust's heat shield.
CRAVEN7786 is offline
post #3 of 9 Old 08-18-2012, 04:25 AM
its typical they all do it. sometimes when i get back after a ride my feet go numb and my hand to
700xxracer is offline
post #4 of 9 Old 08-18-2012, 02:26 PM
Single cylinder engines are prone to vibration, This is the reason for a countershaft. The larger displacement amplifies what the countershaft cannot correct.
90HPXX is offline
post #5 of 9 Old 08-18-2012, 05:39 PM Thread Starter
easystreet's Avatar
Do you mean counter balancer?
post #6 of 9 Old 08-18-2012, 05:42 PM Thread Starter
easystreet's Avatar
Checked my heat shields and they're solid. Thanks for the tip! Have yet to dig into it further. It seems to be much worse than a single cylinder common vibration. I have owned 450R's and they have no counter balancer to save weight. Its a pretty aggressive rattle/vibration.
post #7 of 9 Old 08-18-2012, 07:48 PM
Yes sir, same difference (at least in my twisted mind)
90HPXX is offline
post #8 of 9 Old 08-23-2012, 06:44 AM
I find the 700x has a hell of alot more vibration felt through the pegs than my 450r
froggy is offline
post #9 of 9 Old 08-26-2012, 09:37 PM Thread Starter
easystreet's Avatar
I think I cured my vibration. Not 100% sure what was causing it. I found a slightly loose nerf bar. Some loose plastic around the gas tank. And to my surprise a mildly loose heat shield bolt. I had went out and tapped all around the exhaust and heat shields and didn't hear a vibration. Put an allen wrench on each and did find one a tad loose.
Anyway, I took it down the rode in high rpm's and didn't feel or hear it anymore. Very excited. It was one of those things that bug ya!
