Stage 2 Cam? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 09-09-2012, 08:23 PM Thread Starter
Phil700's Avatar
Stage 2 Cam?
Hello my friends!
On a scale of 1-10 how hard is it to install a stage 2 cam? Also, what mods could I do to my 700 that are under $200.00?
I plan on getting a Lexx Slip on too.
700xx Newbie!
Computer giving you problems? Computers are my specialty! email me any questions and I will answer them as honestly as I can:
Phil700 is offline
post #2 of 6 Old 09-09-2012, 10:01 PM
IMO, I'd save the money and skip the slip on. Yo're better off with a programmer and an air mod of some sort. To keep it really cheap and still be able to feel a difference:
13 tooth front sprocket: $15
EFI Programmer: $200
New air filter: $30
Remove the airbox lid: Free!
As for the cam, it's a 5 in my book due to the not needing to change the valve springs. I wouldn't even think of touching the cam unless I had head work, higher comp piston, full exhaust, efi programmer and an air filter solution.
2008 TRX700XX, Yellow/Black, EHS Big 3, EFM Auto Clutch, DS650 Fenders, 13T, Shorty Clutch Lever, Rear Brake on Bars, Kenda Road Go/ITP.
2000 Polaris Scrambler 400, HPD Trail Mod Complete Package, V-Force Reeds, Mikuni Flat Slide Carb, Flexx Bars, HPD Stabilizer, Fox Podium Rear Shock.
ironchef2009 is offline
post #3 of 6 Old 09-10-2012, 10:31 PM Thread Starter
Phil700's Avatar
Alright thanks man! I'll skip the Slip on, and cam. Thanks for the quick reply!
One more thing, I am a cheapass and plan on running my quad with airbox lid off.
Will this do any damage to my prized machine?
700xx Newbie!
Phil700 is offline
post #4 of 6 Old 09-10-2012, 10:58 PM
Ba9801's Avatar
Make sure you use a good air filter & keep you air filter serviced regularly and you will be good.
Ba9801 is offline
post #5 of 6 Old 09-11-2012, 06:39 AM
Totally agree with above. If you're not a mud riding guy or someone who rides in deep water, you'll be fine. But get the programmer before you just take the lid off. The bike runs a little lean in stock form and you'll make it worse.
post #6 of 6 Old 09-11-2012, 01:14 PM
If you limit is $200, then I would do what ironchef2009 suggested, although I feel the power gains will be pretty minimal. The stock muffler is pretty restrictive, look how small the opening is and it is baffled, so a slip on would provide alot more exhaust flow, since it is just a straight though pipe. I have never tried the Lexx brand slip on's, but I have heard good things about them. I figure all slip on's are pretty much the same, not really a whole lot you can do using the stock headpipe, might as well get the cheapest one you can.
As far as a cam, I believe site sponsor EHS did a before and after dyno test on a "big 3" 700XX and Hot Cams stage 3 cam. (Dyno sheets should be on this site somewhere.) I want to say the quad picked up something like 3 or 4 horsepower after the cam install. My one 700 has the big 3 and I installed a stage 3 cam and it was a noticeable difference. What are your future plans? If you never really plan on getting into the motor, then a Stage 3 cam would be a good investment. Now if you plan on gettting the head ported eventually along with other work, then I would hold off and get a Web cam and spring kit later down the road.
For a budget motor that you never really plan on doing anything else with, I would go with a Lexx slip-on, EFI controller, remove airbox lid, and a Stage 3 cam. Will be a very noticeable difference compared to stock.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
