no spark - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 09-24-2012, 12:53 PM Thread Starter
no spark
alright as the title says i am not getting a spark, i am almost 100% positive that it is not the coil. The fuse to the ignition and fuel injector is good, and the fuel injector is spraying out fuel. also ive tried putting another coil in and nothing,
so i am figuring that it is not getting a signal to fire a spark. so what do you think is going on right now?
thanks for any help.
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #2 of 9 Old 09-24-2012, 01:48 PM
700xxmaniac,
I know that you checked the kill switch but.......
post #3 of 9 Old 09-24-2012, 08:38 PM
headscratch
ecu maybe shorted out
post #4 of 9 Old 09-24-2012, 09:43 PM
AusTrx700xx's Avatar
Have you got a pulse to the coil? To test you will need a led test light, with the ignition on I believe you should have power to both sides, and when cranking you should have a pulse (light should flash) on one side of the plug connector, if it does this you have a coil issue, if it doesnt check the wiring kill switch and stator I believe,
All readyto roost thanks to
Mike at Quadparts.com.au
Team IMS imsproducts.com
George at MonsterLab Atv
Kimberly Motorcycles
Minshull Mechanical Repairs
AusTrx700xx is offline
post #5 of 9 Old 09-27-2012, 12:55 AM Thread Starter
holy shit that's good idea with the led light... ill give that a try when im back home. im 100% positve its not the kill switch, i don't think it will even crank when that's off.
and im perty sure that the stator is fine cuz the injector is still firing. what i think is that either i got bad luck and the second coil i tried was also bad or the cdi shit the bed..
-uni
-primary drive 13t
-pclll
-skyjacker 6'' lift
-sct 100hp tune
post #6 of 9 Old 09-27-2012, 12:56 AM Thread Starter
700xxmaniac,
i had a bad habit of doing that with my recon, but i don't think the xx will crank with the kill switch off.
-uni
-primary drive 13t
-pclll
-skyjacker 6'' lift
-sct 100hp tune
post #7 of 9 Old 09-29-2012, 11:05 PM
Check your bank angle sensor. Mine went bad on me on my cbr1000rr and it drove me crazy for days.
NineLivez2Go is offline
post #8 of 9 Old 10-15-2012, 11:34 PM Thread Starter
Where would that be on the xx?
-uni
-primary drive 13t
-pclll
-skyjacker 6'' lift
-sct 100hp tune
post #9 of 9 Old 10-16-2012, 12:02 AM Thread Starter
also i dont smell fuel anymore, checked both coil and injector wires with the led idea and nothing
-uni
-primary drive 13t
-pclll
-skyjacker 6'' lift
-sct 100hp tune
