Need Valve Help - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 10-11-2012, 06:08 AM Thread Starter
Need Valve Help
When replacing the stock valves with kibblewhites do I have to polish the head or can I clean up the head and replace them? The valves I have are still standard size.
LaLa064 is offline
post #2 of 3 Old 10-11-2012, 09:01 AM
you should have the seats refaced to freshen them up to do it correctly. if you lap them good they will work in a pinch but they need a cutter on the seat to do it correctly imo
EHSRACING is offline
post #3 of 3 Old 10-14-2012, 06:16 PM
Ba9801's Avatar
I just had the head on my Yamaha Warrior done and I put in Kibblewhite valves, springs, retainers, etc... When I did I had the valve seats done at a machine shop to match the valves to the seats. This is really the best way to go to make sure the valves seal properly.
Ba9801 is offline
Tags
engine, exhaust, intake, piston, valves
