clutch engage noise - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 10-13-2012, 09:44 PM Thread Starter
clutch engage noise
ok so when i turn on the xx in neutral with the clutch in is sounds fine and as soon as i let the clutch out it starts to almost knock and is a completely different noise than when the clutch is pulled in...Any idea????
xxdanxx is offline
post #2 of 8 Old 10-15-2012, 12:51 AM
AusTrx700xx's Avatar
At a guess I would say there is a issue with the clutch basket bearing or basket it's self, personally I would pull the clutch cover off and check how much play there is,
All readyto roost thanks to
Mike at Quadparts.com.au
Team IMS imsproducts.com
George at MonsterLab Atv
Kimberly Motorcycles
Minshull Mechanical Repairs
AusTrx700xx is offline
post #3 of 8 Old 10-15-2012, 09:50 AM
mine does the same thing. ive asked around and done quite a bit of research on it and everyone i talk to says its normal
fraiolib is offline
post #4 of 8 Old 10-15-2012, 03:09 PM
mytrx700xx's Avatar
mines done it from new, and still does as I have ran less than 6 full tanks though this thing.
mytrx700xx is offline
post #5 of 8 Old 10-15-2012, 03:40 PM
Quoted: 252 Post(s)
idk about this, but personally I've never held my clutch in while starting in neutral. I would say to maybe try a better quality oil like a full synthetic.
post #6 of 8 Old 10-15-2012, 06:45 PM
grin
it may be the bearing i think honda done a recall on those and the better ones are a different part #.if it is rideable i would put fresh oil in and go until i wont go no more!
post #7 of 8 Old 10-16-2012, 06:53 PM Thread Starter
ok good ill just get a tune up and wont worry about it? after all it is a honda good to know other people noticed it too
xxdanxx is offline
post #8 of 8 Old 10-17-2012, 02:01 AM
2008700xxrider's Avatar
I took mine in the dealer ship, 3 times once partially for a top end ping noise, cause I noticed the same or similar noise and small vibration. when I was in neutral and then pulled the clutch in. I was assured it was"normal" but they made a note for future warranty issues as mine was about to run out. But i've had no real problems with it. Also use full syn oil, klots.
2006 ds650x-sold.
2008700xxrider is offline
