I'd like to lower the gearing on my 700XX - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 11-10-2012, 05:47 AM Thread Starter
I'd like to lower the gearing on my 700XX so that it easier to break the back tires loose. I have new 22" ITP Holeshots in the back, and they grip a little too well. The trails that I ride on are tight so I'm not as concerned with top end speed as I am with low end power. I would have gotten 20" ITPs but I wanted the higher ground clearance.
Could I accomplish this by changing the number of teeth on the front and/or rear sprockets? If so, how should they be changed. Thanks.
hellishot is offline
post #2 of 6 Old 11-10-2012, 08:26 AM
Just change the front to a 13t, price ranges from below ten bucks to just over $20.00. You can do it by changing rear too, but front it far easier and cheaper. IMO the TRX should of shipped with a 13 tooth front sprocket. Info below but read thru it, I think 1st post says tip quad on rear rack. That's not necessary, just use a extension and a swivel to get front sprocket bolt broke loose.
https://www.club700xx.com/vb/showthread.php?t=2898
post #3 of 6 Old 11-10-2012, 08:31 AM
But if your talking about breaking tires loose on a corner, L8ton rear sway bar for around $220.00
http://www.l8tonracing.com/default.asp
post #4 of 6 Old 11-11-2012, 05:46 PM
Or you could either up the preload on the rear shocks or add a little more air to the rear tyres. If this fails then either L8ton or ride faster.
post #5 of 6 Old 11-12-2012, 03:48 PM Thread Starter
I didn't know that the rear shocks were preload adjustable, I will definitly do that along with going to a 13t front sproket. Thanks for the help!!!
post #6 of 6 Old 11-12-2012, 04:14 PM
All ATV shocks that I've seen let you adjust preload but only high-end shocks allow compression and rebound adjustments. The preload as I understand it is just the outer springs. Use a spanner wrench, but remember to keep both side the same.
