Sponsored Links | |||
sounds to me like your clutch is toast, ive read alot of clutch issues on here and im experiencing them myself. i put the kit that EHS offers in it and it hasnt been right since then, gonna try the hinson kit next and im pretty sure other stuff will be worn out in there also.
Are you using the correct oil, it must be wet clutch safe. You can't use normal automotive motor oil. This will really burn up a clutch fast. If this is the problem I would just get a replacement stock clutch and change the oil & filter with the correct wet clutch safe oil. I use Honda HP4S oil in mine.
Sponsored Links | |
Thread Tools | |
Display Modes | |
Posting Rules | |
