My Brother needs Help! - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 11-25-2012, 02:54 PM Thread Starter
ok so my brother bought a 300ex, what a mistake he should have a bought an xx haha but anyway it makes a weird tick i dont think its the timing chain because its not constant it goes away for 10 seeconds the comes back for 5 its weird and we are both stumped any idea what it could be let me know????
xxdanxx is offline
post #2 of 3 Old 11-25-2012, 03:08 PM
Snoshoe's Avatar
can you tell from where in the motor? how is the idle? if it is to low the compression release will kick in. does it go away when you give it gas? or when you let off? when was the last oil change? metal in filter?
$1 for an answer
$4 for an answer which requires thought
$7 for an answer which could be true
$10 for the correct answer
2008 TRX700xx
13Tfront
Kenda Bear Claws 23x8x11
Custom 2" receiver
rear seat/ strorage box
Ground Hog Disk harrow kit
PEI fog lights
Snoshoe is offline
post #3 of 3 Old 11-25-2012, 04:01 PM Thread Starter
towards the left side of the motor when on the bike and it happends when you you let off and it returns to idle it will give a couple of high pitch tings i have not done an oil change recently because my drain bolt it chewed up i have to order a new one and filter it also back fires alot may not be jetted for hmf slip on if that helps
xxdanxx is offline
