2 Questions?? - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 12-10-2012, 04:38 PM Thread Starter
2 Questions??
So i want to beef up my xx a little give it some sound so i want a slip on but if i get one will i NEED a fuel programmer or will it just be fine Secondly i think my valves need to be adjusted should i do it my self or drop the 150 to get it done if someone could post a how too video that would be awesome because i cant find any Thanks
xxdanxx is offline
post #2 of 8 Old 12-10-2012, 05:25 PM
i wouldnt waste my money on a slip on , there is vids on you tube on the valves
post #3 of 8 Old 12-10-2012, 05:52 PM Thread Starter
i looked at the vids on you tube cant find any off xx and i would buy the slip on now then when i get more money buy the header
xxdanxx is offline
post #4 of 8 Old 12-11-2012, 12:56 AM
Ba9801's Avatar
Save your money and get a full system and a programer at the same time. This way you can tune it all at once. Realistically a slip on will only give you a bit of power by itself and any good slip on should be programed. Many guys have gotten away with just adding the slip on but these bikes already run on the lean side from the factory. It really depends on your elevation as well.
Ba9801 is offline
post #5 of 8 Old 12-11-2012, 01:35 AM
You get those beadlock off of ebay ???
700xxracer is offline
post #6 of 8 Old 12-13-2012, 07:21 PM Thread Starter
ok but as far as the valves what do you think
xxdanxx is offline
post #7 of 8 Old 12-13-2012, 07:22 PM Thread Starter
ok i will but what do you think i should do about the valves
xxdanxx is offline
post #8 of 8 Old 12-19-2012, 11:42 PM
Quoted: 260 Post(s)
Download the service manual, and by a decent set of feeler gauges. That is if after reading manual your up for challenge!
