intermittent tick in my motor. - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 01-06-2013, 02:27 PM Thread Starter
In the past couple months I have noticed that after I ride for a bit, turn off the quad, then start it back up, it has an intermittent tick, that almost sounds like the cam chain is slapping or something. But it only happens while idling, or I only hear it then, and it doesn't do it every time. I would rather figure it out before I have some kind of catastrophic failure, but I have no idea what it could be. I would think if it was the chain tensioner it would happen all the time.
Any body have any ideas?
08 700XX
06 400EX
04 TRX90
98 TRX90
12 Raptor 125
07 Seadoo RXP
06 Seadoo RXP
exhausted is offline
post #2 of 12 Old 01-06-2013, 04:09 PM
Snoshoe's Avatar
funny but idling puts less tension on the timing chain alowing it to "slap".
I had the same problem with a KLR 600 the timing chain adjuster was loose, tightened it no more tick.
low oil lvl may do it too
2008 TRX700xx
13Tfront
Kenda Bear Claws 23x8x11
Custom 2" receiver
rear seat/ strorage box
Ground Hog Disk harrow kit
PEI fog lights
Snoshoe is offline
post #3 of 12 Old 01-06-2013, 05:58 PM
all i can think of is it could be something in cam chain assembly or the vavles are ticking. and need adjusting
post #4 of 12 Old 01-07-2013, 08:36 AM Thread Starter
I wouldnt think it was the valves since its so erratic, but I will def check them. I'm also gonna check the tensioner, but not sure what a visual inspection is gonna show me. I may just buy a new tensioner to rule it out.Are they an easy swap?
08 700XX
06 400EX
04 TRX90
98 TRX90
12 Raptor 125
07 Seadoo RXP
06 Seadoo RXP
post #5 of 12 Old 01-14-2013, 02:07 PM Thread Starter
I replaced the tensioner and its still happening. Do clutches ever make that noise when the baskets start coming apart? cause I also have a low rpm vibration noise in low gears while riding sometimes.
08 700XX
06 400EX
04 TRX90
98 TRX90
12 Raptor 125
07 Seadoo RXP
06 Seadoo RXP
post #6 of 12 Old 01-20-2013, 09:40 AM
I have the same problem. Very intermittent and only happens for a second on start up. This occurred after cam install. I put in a web stage 2 cam, the first cam was really bad (intermittent ticking)and intermittent hard start, almost like a dead battery, hard to turn motor over. Web had me send it back in and told me that it was a faulty/sticky decompressor. Put the second cam in and was way better but still occurs once in a great while. Unfortunately, so far, I have just learned to deal with it. Maybe I will look into it again and troubleshoot.
Seabass is offline
post #7 of 12 Old 01-20-2013, 11:41 AM
exhausted it may be the clutch basket bearing i think honda has a differnt bearing now than what comes in them,they upgraded one of those bearings in the clutch assembly baxter prolly knows something about it
post #8 of 12 Old 01-22-2013, 06:08 PM Thread Starter
That sounds just like mine. i forgot about it doing the slow crank on starts sometimes too. It all started after i had my piston replaced too.
08 700XX
06 400EX
04 TRX90
98 TRX90
12 Raptor 125
07 Seadoo RXP
06 Seadoo RXP
post #9 of 12 Old 01-26-2013, 12:14 PM
I also put in a new CP piston when the cam was installed.
Seabass is offline
post #10 of 12 Old 10-01-2013, 11:34 AM Thread Starter
Just as an FYI, My motor tick got gradually worse so I decided to let my Neighbor who is a motorcycle mechanic find the problem. It ended up being the decompression mechanism on the cam. It is pressed on and from what I read, the after market cams don't come with new ones and you are supposed to re use your stock one with them, and of course Honda doesn't sell them separate, so I ended up buying a whole new stock cam. Sounds way better than even before I got the tick noise too. Motor is much more quiet now.
08 700XX
06 400EX
04 TRX90
98 TRX90
12 Raptor 125
07 Seadoo RXP
06 Seadoo RXP
