Bored Throttle body - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 01-20-2013, 10:26 PM Thread Starter
Quoted: 5 Post(s)
Bored Throttle body
I have one i bought used i have it on an it has a hard time comin back to idle any ideas?
Elmer is offline
post #2 of 9 Old 01-20-2013, 11:17 PM
skier207's Avatar
I remember Smooth and someone else had trouble with this same issue.
Looking......
Heres one. > https://www.club700xx.com/vb/showthre...highlight=idle
skier207 is offline
post #3 of 9 Old 01-21-2013, 01:38 AM
easystreet's Avatar
I'll be sending mine off soon. Hope I don't have these issues. Let us know what you find out Elmer.
'08 710XX
+3mm HotRods stroker crank
Port & Polish (myself)
HotCam 3
Velocity intake
PCV (dyno tuned)
easystreet is offline
post #4 of 9 Old 01-21-2013, 07:14 AM
valk680's Avatar
I would check to make sure your cable isn't hanging up somewhere. If thats good check to see if the butterfly is touching the body and there is not to much free play in the cable. It took me about an hour to get the adjustment just right.
I used to have idle issues at start up. Now she idles better then stock.
Easystreet, If you haven't sent yours out yet check out Sredrum machining.
he did mine and it came out perfect and he was the cheapest.
715 11:1 big bore
+1 intake valves
Sredrums +3 throttle body
PCV
NGK BKR6EKPB-11 spark plug
K&N air filter w/outerwares,
Barker exhaust
PBI sprockets /D.I.D chain
Stage 3 Elka's on all 4 corners
valk680 is offline
post #5 of 9 Old 01-21-2013, 12:42 PM Thread Starter
Quoted: 5 Post(s)
Thanks
Elmer is offline
post #6 of 9 Old 01-26-2013, 07:42 PM
There's 2 reasons for a high idle. One is some sensor needs resetting , the other is a bad bore job and the butterfly valve doesn't seal the bore. Sounds weird but got a CRF throttle body that was done badly. Can see daylight when closed.
post #7 of 9 Old 01-29-2013, 10:58 AM Thread Starter
Quoted: 5 Post(s)
Ya going to put my stock one back on!!!
Elmer is offline
post #8 of 9 Old 01-29-2013, 08:37 PM
. Sounds weird but got a CRF throttle body that was done badly. Can see daylight when closed.[/QUOTE]
thats not good im wondering now who would do the job right the first time if it wasnt right that would aggravate the shit out of me and prolly wouldnt do business with them again!
post #9 of 9 Old 01-30-2013, 02:46 AM
How big a difference does a bored throttle body make? How much does it affect the tuning?
2008 trx700xx grey & black fmf titanium 4 full system air box lid mia dynojet pc III tuned by me. Trailtech vapor with a custom dashboard I built. Hardly ridden yet...
dixon700 is offline
