Flywheel removal - bolt size? - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 01-21-2013, 01:35 AM Thread Starter
easystreet's Avatar
Looks like it only takes theading a bolt into the flywheel which then pushes against crankshaft end. Looks simple enough, but I can't find a bolt in my tool box thats the right size and thread pitch. Appears to be 19mm maybe.
Anyone know off hand? If not, I guess I head to Fastenal to buy all close options in the morning.
'08 710XX
+3mm HotRods stroker crank
Port & Polish (myself)
HotCam 3
Velocity intake
PCV (dyno tuned)
easystreet is offline
post #2 of 4 Old 01-21-2013, 02:24 PM Thread Starter
easystreet's Avatar
Alright, I figured out what it takes. You need a 3/4" fine thread bolt. No specific pitch. You have coarse or fine. Worked like a charm. Flywheel is off!
I figured for sure it would be metric 19mm. Guy at Fastenal said there are no non custom 19mm bolts. Goes from 18mm to 20mm in the bins. Took a long shot chance that it could be standard unit 3/4" and got lucky.
'08 710XX
HotCam 3
Velocity intake
PCV (dyno tuned)
post #3 of 4 Old 01-26-2013, 07:36 PM
You're kidding ! try M20x1.5 mm. You can get a Motion Pro flywheel puller, same as 400ex and XR650r.
http://www.ebay.co.uk/itm/MOTION-PRO...item2579d02702
post #4 of 4 Old 01-26-2013, 08:16 PM Thread Starter
easystreet's Avatar
Wow! Thats a $14 tool. Got a bolt for a couple bucks.
'08 710XX
HotCam 3
Velocity intake
PCV (dyno tuned)
