Help....engine surges in reverse - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 01-21-2013, 04:45 PM Thread Starter
Today I started the 700xx to move it. I had a ride two days ago and everything was fine. Today I put it in reverse, gave it some throttle and the engine began surging. If I gave it full throttle it would somewhat clear up. But as soon as I tried to move backward again, back comes the surging. Moving forward through the gears everything is fine. This only happens in reverse and I have no idea what to look for as far as a fix is concerned. Has anyone had, or heard of this issue. Any help would be greatly appreciated.
jnjlizak is offline
post #2 of 4 Old 01-21-2013, 05:22 PM
easystreet's Avatar
There is a reverse rev limiter on the XX. Sounds like it is acting up. Do some searching on "reverse rev limiter" and see if anything comes up. I know I have seen discussions on disconnecting that limiter.
'08 710XX
+3mm HotRods stroker crank
Port & Polish (myself)
HotCam 3
Velocity intake
PCV (dyno tuned)
easystreet is offline
post #3 of 4 Old 01-21-2013, 07:40 PM
Definitely a good idea to by pass the reverse limiter.
https://www.club700xx.com/vb/showthread.php?t=2312
It may also be a good idea to look and the sensor's. Look at part #11 in this drawing. The one on the left is the neutral sensor the one on right is the reverse sensor. I tore my boot on part# 10 and when quad ran into deep water it would stall out. And later the ceramic on the sensor cracked so I replaced it and the wire harness. These sensor's are on the left side by the foot sifter. To access I had to remove side plastic and heel guard. But I got big monkey hands, lol
http://www.cheapcycleparts.com/model...0169-crankcase
post #4 of 4 Old 01-22-2013, 06:13 PM Thread Starter
Thanks for The advice
Thanks for the help. I'll let you guys know what I find out.
jnjlizak is offline
