Can i use regular oil? - Club700XX - Honda TRX700XX Forum
post #1 of 28 Old 01-29-2013, 05:12 PM Thread Starter
Can i use plain oil for a oil change? When i did changes on my VTX it just had to be non energy conserving?
Thanks
blackflame is offline
post #2 of 28 Old 01-29-2013, 05:16 PM
BuckeyeXX's Avatar
Absolutely not. It must be wet clutch compatible. If you don't use an oil compatible your clutch will start slipping!
08 700XX Black/Gray
01 90 Yerf Dog
BuckeyeXX is offline
post #3 of 28 Old 01-29-2013, 05:57 PM Thread Starter
That is the reason behind non conservative, so it doesn't affect the clutch. never had a problem with my VTX 1800 slipping the clutch.
post #4 of 28 Old 01-29-2013, 08:03 PM
it will tell you on the bottle if it is wet clutch safe
post #5 of 28 Old 01-29-2013, 09:24 PM
BuckeyeXX's Avatar
I'm not tryin to convince you use an oil made for wet clutch but it a must in these quads. As stated above just look on the bottle to see the compatibility. Here is a link so you can download the manual. http://www.hondaatvforums.net/forums...all-years.html
08 700XX Black/Gray
01 90 Yerf Dog
post #6 of 28 Old 01-29-2013, 09:41 PM
Snoshoe's Avatar
My understanding is that regular auto type oil contains additives to improve lubracation, resist sludging, and the such. In wet cluched vehicles ie atvs and motorcycles those addidtives are circulated and because of the porsusness*? of the disks the addidtives are collected there and eventually reduce fiber/ plate grip thus ruining your clutch plates.
As stated above you need to be sure the oil is made for use in wet cluch applications.
2008 TRX700xx
13Tfront
Kenda Bear Claws 23x8x11
Custom 2" receiver
rear seat/ strorage box
Ground Hog Disk harrow kit
PEI fog lights
Snoshoe is offline
post #7 of 28 Old 01-30-2013, 02:31 AM
I'm running castrol rs 4t. I have 10w-50, should have 10w-40, but grabbed wrong bottle.
2008 trx700xx grey & black fmf titanium 4 full system air box lid mia dynojet pc III tuned by me. Trailtech vapor with a custom dashboard I built. Hardly ridden yet...
dixon700 is offline
post #8 of 28 Old 01-30-2013, 05:30 AM Thread Starter
Ok i'll look into it more. The bike was a wet clutch also, always ran regular car oil (syn) and as long as the label did not say energy conserving, because some do some don't. Maybe less additives with no label???
post #9 of 28 Old 01-30-2013, 08:25 PM
Quoted: 252 Post(s)
Good stuff, and the Honda likes it.
http://www.mobiloil.com/USA-English/...4T_10W-40.aspx
post #10 of 28 Old 01-31-2013, 06:33 AM Thread Starter
10-40 be ok for winter?
