Slip on need programmer? - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 02-04-2013, 10:40 AM Thread Starter
If I buy a slip on pipe will I need a optimizer/programer
hondaman897 is offline
post #2 of 4 Old 02-04-2013, 02:40 PM
NO... A slip on does not do much in the way of adding power. Additional power usually comes from the aftermarket header in a full system. Be careful, if your intent is to upgrade to a full system later, your slip on now probably won't fit to the new header (larger diameter head pipe)... a slip on will be made to fit your smaller stock head pipe.
post #3 of 4 Old 02-04-2013, 05:08 PM
Quoted: 252 Post(s)
If I was to buy one or the other, I'd get the programmer. Although it is not needed for just adding the slip on exhaust. The Trx700xx will run much better with a programmer and a good map.
post #4 of 4 Old 02-08-2013, 03:52 PM
Agreed they are well worth the money plus they are programable for future mods. I went big gun great power easy to program. Cost about 180$
NoWingNoPrayer is offline
