kibblewhite valves - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 02-05-2013, 02:02 PM Thread Starter
kibblewhite valves
Hey guys - I'm upgrading to a 11:1 piston and HC3.. (with the big 3 of course)
Would there be any reason to upgrade to kibblewhite valves??? My stock valves are fine right now currently....
cbulldog99 is offline
post #2 of 4 Old 02-05-2013, 09:07 PM
no i wouldnt do that until it needs it and then you may want to go ahead and port and polish and go 1 over on the valves
post #3 of 4 Old 02-06-2013, 11:16 AM Thread Starter
One more question... When installing a new piston, the manual specifically calls for the use of "molybdenum oil"
Do I need to go find some of this? OR can I just use regular engine oil or gear oil inside the rod inner surface?
post #4 of 4 Old 02-06-2013, 04:47 PM
gets some assembly lube from napa or someplace oil will work but lube is better it stays put
ive been using redline which i like but it wont be at napa the white stuff they use on chevy stuff will work
EHSRACING is offline
