Just installed FMF 4.1 with Powerbomb - Club700XX - Honda TRX700XX Forum
post #1 of 24 Old 04-29-2009, 11:25 AM Thread Starter
ara
I finally got to install it, and sounds pretty good. Not too loud...just about right.
I am going to install the factory header plate with some silver reflective tape to help keep heat away from my leg a little.
I get this whistle noise after shutting it down...anyone else hear this noise?
ara is offline
post #2 of 24 Old 04-29-2009, 11:29 AM
would you mind recording a sound clip of it?
Jeff and I would be eternally grateful.
post #3 of 24 Old 04-29-2009, 11:45 AM
Never heard a whistle noise from mine. Did you use silicone on the header/slipon connection?
post #4 of 24 Old 04-29-2009, 11:56 AM Thread Starter
ara
Yes, the high temp red silicone
ara is offline
post #5 of 24 Old 04-29-2009, 11:56 AM
post #6 of 24 Old 04-29-2009, 11:57 AM Thread Starter
ara
Give me till tomorrow, and I will try to record a sound clip.
ara is offline
post #7 of 24 Old 04-29-2009, 12:02 PM Thread Starter
ara
whistle = an exhaust leak btw.
Could be. It's not while running, atleast I didnt hear it. It whistles only after i shut it off. I thought I applied alot of that silicone....most of it got squeezed out.
Maybe I need to run it a few minutes and let everything settle in. Regardless, it sounds nice.
ara is offline
post #8 of 24 Old 04-29-2009, 12:05 PM
You should hear it when you rev the engine and let off also.
post #9 of 24 Old 04-29-2009, 12:15 PM Thread Starter
ara
Its definately comming from the rear/can area...but cant really hear anything but loud rumble when reving
ara is offline
post #10 of 24 Old 04-29-2009, 12:23 PM
Maybe as it's cooling and sucks in a bit of air it whistles through the spark arrestor
