Would it be ok to run HONDA HP4S synthetic 10w30 Motor oil in the 700xx? - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 02-25-2013, 01:34 PM Thread Starter
Im not sure what weight motor oil I suppose to use in my 700xx as I havn't looked in the manual yet only had it changed at the dealer but was wondering if it would b ok and good to use HONDA HP4S 4-STROKE MOTORCYCLE OIL 10W-30 in it. I don't ride my 700xx muxh and dont have time to change to oil often in it and was wondering if switching to the synthetic would b safe to use and be better for my bike where i dont get to change to oil often. Thinking about switching to synthetic in my 680 Rincon and 420 Rancher at too. What do u guys think? THANKs!
04honda is offline
post #2 of 9 Old 02-25-2013, 01:47 PM
As long as your oil is made to be safe for a wet clutch, you should be OK.
post #3 of 9 Old 03-05-2013, 03:58 PM
I was about to do the same thing, then went to the Honda shop and asked the guys in the service department about that. They said only run that oil if you want your clutch to start slipping. They said only run GN4.
ckozma is offline
post #4 of 9 Old 03-09-2013, 04:34 PM
damn i my shit is sliping
I just got my 700... just put hp4s in it. had no issues with it in my 400ex. now after 45 min of riding the fucking clutch feels like its slipping.... then I see this thread...
Baynedo is offline
post #5 of 9 Old 03-09-2013, 07:08 PM
BuckeyeXX's Avatar
Guys I'm here to tell you that it is ok to run the synthetic oil. Your clutch isn't going to slip because of the synthetic. You either already have an issue or your not using an oil compatible with the wet clutch witch is vital in these machines.
08 700XX Black/Gray
01 90 Yerf Dog
BuckeyeXX is offline
post #6 of 9 Old 03-09-2013, 08:18 PM
[QUOTE=ckozmaThey said only run GN4.[/QUOTE]
thats what ive always run and no clutch probs! its all about what each rider prefers in the oil!
post #7 of 9 Old 03-14-2013, 10:21 PM
Ba9801's Avatar
HP4S is the only oil I have ever run in both my 07' 400ex's and my 08' 700XX and they are all still on their original clutches. I have never had any issues at all. I change my oil ever 3-4 months. Better safe than sorry.
Ba9801 is offline
post #8 of 9 Old 04-02-2013, 12:04 AM
Hp4s was not the issue of my clutch. My clutch cable was way out of adjustment. Mine is fixed
2008 700xx
Custom exhaust
Yoshimura carbon Rs3 muffler
Power Commander V
Honda Racing Nerf bars.
Honda Racing Shock covers
Maxxis razr 22x7x10 6ply fronts
Maxxis razr 22x10x11 6ply rear tires
L8ton 11/16 rear sway bar
Uni filter
Engine ice
Honda HP4S Oil
Custom vynil black seat (it gripps the cheeks)
6000k Hid's
DEI coated exhaust (black)
Made 47.5 Whp baseline was 37whp
Baynedo is offline
post #9 of 9 Old 04-06-2013, 12:00 AM
well if you come from a cvt trans ill give you a break but if not well thats what most rookie lever pullers do is abuse the clutch especially in them 13 tooth situations that i can use a 14 with the same results its just knowing how to be easy on the clutch some people never master it therfore they go thru more clutches,its easier to do if you started out riding a clutch at a very young ageis this your first manual atv?
