coolent - Club700XX - Honda TRX700XX Forum
post #1 of 14 Old 02-26-2013, 10:24 PM Thread Starter
IIIBuckIII's Avatar
coolent
hey guys im about to flush the radiator befor riding season im thinking of running engine ice . what do you guys recommend
IIIBuckIII is offline
post #2 of 14 Old 02-27-2013, 07:28 AM
I run Peak 50/50. I have never tried any of the non-glycol based coolants.
post #3 of 14 Old 02-27-2013, 07:39 AM
2008700xxrider's Avatar
I'm about to do a flush aswell. Installing a trail tech vapor.. I'm going to use engine ice. I know his that run it in all they're bikes including race bikes. From what I understand you just can't mix them. You get a bad reaction ha.
2006 ds650x-sold.
2008700xxrider is offline
post #4 of 14 Old 02-27-2013, 02:44 PM
1dmbhonkey's Avatar
I've been running engine ice for about a year..... No issues yet. As far as cooler running, I couldn't tell any difference without a temp gauge.
1dmbhonkey is offline
post #5 of 14 Old 03-08-2013, 02:49 PM
I got the change done and I have a temp gauge (tt and infrared) at idle it gets to 215 and the fan kicks on. Its only 45 degrees here now. Riding up and down the street it keep it at 185-195. Should the fan have to kick on at idle? I never noticed that before. Just worried for when it gets 100at the dunes this summer
2006 ds650x-sold.
post #6 of 14 Old 03-09-2013, 08:55 AM Thread Starter
IIIBuckIII's Avatar
my fan kicks on when i start it to let it run then walk off for about 10 min thats normal for it to kick on to xx is a very hot running motor i use to be worried about mine also if you want to check it make sure is running correct all you have to do is unplug the fan and turn your key on if it kicks on then its fine
Prm Desert II bumper
Alba Pro Elite Nerfbars Silver/Black
Alba Gas Cap Red
DWT .190 with GBC XC-Master 22x7 Front
DWT .190 with GBC X-REX 20X11-10 Rear
EHS Air Lid
EHS Controller
BigGun EVO-R Full Exhaust
UNI Filter
Tusk 30mm Riser Extenders
post #7 of 14 Old 03-09-2013, 09:40 AM
Oh I know the fan is working great. buck did you end up using engine ice? I guess I never noticed it kick on just siting at idle unless I was out riding hard. I will be paying much more attention to it for a while. As for the engine ice, so far i'm very unimpressed. I did get the one with-25 freeze protection to. I'll wait until its hotter out and see how it does then before I decide to flush it out.
2006 ds650x-sold.
post #8 of 14 Old 03-09-2013, 10:06 AM Thread Starter
IIIBuckIII's Avatar
No iv not used it yea I don't think ill change it all the levels seem good so I think ill leave it alone for now
Alba Gas Cap Red
EHS Air Lid
EHS Controller
UNI Filter
post #9 of 14 Old 03-09-2013, 02:31 PM
I'll past back when I get some more riding time on it.
2006 ds650x-sold.
post #10 of 14 Old 03-13-2013, 10:07 AM
StewPidass0's Avatar
Mine ran about 5 degrees hotter with engine ice. I removed it & temps went back down.
StewPidass0 is offline
