Advice on my build - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 02-28-2013, 08:12 PM Thread Starter
Advice on my build
So heres what im thinking.. i have about 1000 bucks to spend on rebuilding my bike.. as it sits now the only thing aftermarket on it is the fmf exhaust with the powerbomb header. Ive done a little research, and heres what I was thinking:
CylinderWorks +3mm 727 big bore kit
Stage 3 Hot Cam
DynoJet PC5 Programmer
Unifilter
Ehs Airbox lid
Port and Polish my head - Im not sure about this, and I dont know if it fits into the budget at the time, which i why I put it last. How much is a port job? How much gain do I get from it? Who would yall recommend to do the work?
What do you guys think? Im open to any and all suggestions!
softparade is offline
post #2 of 11 Old 03-01-2013, 10:38 AM
2008700xxrider's Avatar
Great list! Sorry to say that's gonna be over your budget.. A pc5 is like 450 alone. Also id find slip on to complete you're exhaust. Good luck on your build!
2006 ds650x-sold.
2008700xxrider is offline
post #3 of 11 Old 03-01-2013, 02:58 PM
IMO there isn't any reason to do a big bore unless you are going to do a port and polish, and possibly bigger valves. That's my two cents though. You could go to a higher compression piston instead of the big bore, and do everything else, and save yourself a few hundred. A port and polish is pretty reasonable depending on who you have do it. Some guys charge a lot, others dont, but as the old saying goes, you get what you pay for. The airbox lid isn't required, as long as you do regular maintenance on your air filter. If you go with the HC3, you should think about buying a better battery as well, to help turn it over easier. You could talk to Eric at EHS for a port job, Velociraptor, or DL. They have all done them on the XX. If you do this build, you should spend some money on getting it Dyno'd as well.
post #4 of 11 Old 03-02-2013, 08:57 PM
Quoted: 252 Post(s)
PCV for $450 where do you shop? I guess not here>>>
http://www.indysuperbike.com/Power_C...X-8906390.html
And no way I'd build a motor and settle for a slip on, just my $0.02...
post #5 of 11 Old 03-02-2013, 09:31 PM
easystreet's Avatar
He has a full pipe already. I'd go Hotcam 3, CP 11:1 stock bore piston, velocity filter kit, tuner of choice and if you have a dremel do the P&P yourself. Be around $800 with new gaskets.
'08 710XX
+3mm HotRods stroker crank
Port & Polish (myself)
HotCam 3
Velocity intake
PCV (dyno tuned)
easystreet is offline
post #6 of 11 Old 03-02-2013, 10:29 PM
Is your cylinder ok? If so, you are going to get more bang with p&p, cam, and hi-comp piston. If you have to get a new sleeve and want to go big, the cam can be dropped in later if you don't have the funds now. Just leaving some horsies on the table for later. Either way, you will need to do the p&p to make her flow. Jut my opinion.
post #7 of 11 Old 03-03-2013, 12:34 PM Thread Starter
Thanks for the advice so far folks. I bought this cylinder works big bore kit last week for 450
( http://www.amazon.com/Cylinder-Works...er+works+11009 )
So I have about 500$ left. I already have an exhaust and header as I said earlier. That power commander says it fits 2009.. mines a 2008.. will it still work???
post #8 of 11 Old 03-03-2013, 04:19 PM
yes the pcv will work the 08 and 09 xx,s are the same
post #9 of 11 Old 03-05-2013, 04:20 PM
Quoted: 252 Post(s)
Yea what he said, I've been running one on my 08 for a minute.
post #10 of 11 Old 03-05-2013, 11:52 PM Thread Starter
So, big bore kit and pcV will match up well together performance wise? Also, what am I going to do about programming? Not sure if there is a dyno around here.
