2Bros Exhaust - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 05-14-2009, 07:54 PM Thread Starter
2Bros Exhaust
Well! Tried to install my VALE exhaust but the canister bracket does not line up with the support bracket so spoke to 2Bros and they haven't seen this issue before. As anybody else seen this issue. The mid-pipe lines up perfectly but not the canister. We'll see what they have to say once they see the pictures.
post #2 of 9 Old 05-14-2009, 08:52 PM
Check to make sure that the slip on is as far down the headpipe as possible. Also, I'm sure you did this but make sure that you keep the VALE part loose until you have all the rear bolts in.
post #3 of 9 Old 05-14-2009, 09:37 PM
Mine was real tight too. Try slightly spinning the lower pipe to change the angle slightly on the slipon. I had to do this three times before it lined up. Spray a little windex on the lower pipe and it will slide on a lot easier.
Colorado 700XX is offline
post #4 of 9 Old 05-15-2009, 06:39 AM Thread Starter
Thanks for the info, the mid pipe is all the way on and the bracket lines up properly, have tried different angles on the mid pipe and the canister's attachment point still does not line up, awaiting to hear back from 2Bros
post #5 of 9 Old 05-15-2009, 04:30 PM
TRX_Sixpac_700xx's Avatar
I know mine took a lot of finessing before I got the exhaust in far enough to get the bolt in as well.
TRX700XX
-UNI Air Filter
-2Bros Exhaust
-2 Bros Juice Box
-13T Sprocket
-Pro Armor Fat Pegs (Black)
TRX_Sixpac_700xx is offline
post #6 of 9 Old 05-16-2009, 09:30 PM
RacerX901's Avatar
it will fit , mine was the same issue just work it around on header some more.....
RacerX901 is offline
post #7 of 9 Old 05-16-2009, 10:10 PM Thread Starter
After coming back from riding this afternoon, tried it again and with modification towards my rear grab bar since it's a PMR Baja grab bar, it finally fit but it's still offset but will work. Now I need to order a P3 tip since the P1 is tad too loud for me. Wish that Supertrapp would come out with one, had it on my 400EX and love the sound.
Thanks for the info/help
post #8 of 9 Old 05-17-2009, 10:57 PM
Did you take your rear fenders off to install that?
post #9 of 9 Old 05-18-2009, 06:37 AM Thread Starter
Rear and Side covers were removed which made life easy but that was the case since the beginning. Now, it's all done, yahoo!!
