Fuel getting into Oil - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 07-20-2013, 11:24 PM Thread Starter
headscratch Fuel getting into Oil
I have a 2008 TRX 700XX and I recently noticed a small noise in the enigne and my oil dip stick smells like gas? Any answers and what's causing this ?
mr_plainjane is offline
post #2 of 9 Old 07-21-2013, 04:58 AM
you didnt pour gas in the oil tank ?? thats a first , never heard this before, i dont know
post #3 of 9 Old 07-21-2013, 08:46 AM
If you have any kind of fuel tuner its up too high. Happen to me and the clutch was slipping a bit.
NoWingNoPrayer is offline
post #4 of 9 Old 07-22-2013, 04:38 AM Thread Starter
No I did not pour gas in oil reservoir, I just noticed my oil on the dip stick rising and it smelt like gasand with it being fuel injected I did not know.. and no I don't have a fuel programmer its all stock except DG nerf bars..
post #5 of 9 Old 07-22-2013, 12:48 PM
needs a piston more than likly
EHSRACING is offline
post #6 of 9 Old 07-22-2013, 08:25 PM
Welcome to the Club! As far as your problem I'd go with EHS, same thing I was thinking but just the piston rings. At least I know that happens with car engines.
post #7 of 9 Old 07-22-2013, 10:11 PM Thread Starter
Alright thats what I was thinking should I just buy rings or everything, like a piston kit and should I get stock piston or a +2mm or something like that.. what do you prefer?
post #8 of 9 Old 07-23-2013, 05:31 AM
I'd go bigger amd get the kit. EHS said piston. I was just thinking how rings go on cars, but he's the one with the engine know how on the trx's. Napa has nothing on Eric, lol. Defiantly tear it down and check for more damage before you order. I'm not sure if Eric has big bore kit recommendations or not, I'd check with him or maybe he will answer for you. Where about are you from, his shop is by the Rockingham speedway in NC.
post #9 of 9 Old 07-23-2013, 08:11 AM
rings could possibly fix it but honestly i would never tear down a motor and just rering a stock piston unless i guess i was doing it for myself and wanted to keep it as cheap as possible just makes sense to put a higher comp better piston in it imo.
also when rings are worn generally the piston will be worn also a little skirt wear goes a long ways in wearng out the bore
Tags
700xx, engine, oil, problems
