Larger Capacity Oil Tank - Club700XX - Honda TRX700XX Forum
post #1 of 33 Old 05-15-2009, 07:20 AM Thread Starter
Would anyone be interested in buying a larger capacity tank (approx. 1 liter/1 qt. more)?
MRP530 is offline
post #2 of 33 Old 05-15-2009, 08:14 AM
post #3 of 33 Old 05-15-2009, 09:16 AM
What is the advantage? Extended drain intervals?
iowa fan is offline
post #4 of 33 Old 05-15-2009, 09:22 AM
Since EVERYTHING goes into the oil on a 700xx, clutch bits, carbon from the combustion process and so on having more oil to dilute it would mean less of a concentration of that stuff circulating through your engine. If you were say a baja racer that would mean better engine protection since you're WOT (I'm assuming) most of the time.
Even though the engine is water cooled and the radioator does an excellent job cooling the engine, it would be cool (no pun intended) if the larger capacity tank had some cooling fins or something like that.
post #5 of 33 Old 05-15-2009, 10:44 AM
So longer drain intervals then
iowa fan is offline
post #6 of 33 Old 05-15-2009, 10:53 AM
Yeah. That.
post #7 of 33 Old 05-15-2009, 12:03 PM
I would still change it at my current interval of 3 rides regardless if the cooler holds an extra quart or not. It holds about a quart now, so holding 2 doesn't mean you should double the time between changes. Oil is cheap. Engines are not. I think the biggest benefit from a larger capacity oil tank would be a slight reduction of oil temp, thus increasing engine life.
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #8 of 33 Old 05-15-2009, 12:29 PM
Oh I change my oil more than you then. Pretty much after each ride.
post #9 of 33 Old 05-15-2009, 12:38 PM
BiFfMaN's Avatar
I actually had the idea to make a finned Aluminum tank...to help cool also. It gets hot out here so any extra cooling helps
BiFfMaN is offline
post #10 of 33 Old 05-15-2009, 12:46 PM
BiFfMaN's Avatar
but actually come to think about it....even adding a Oil cooler would increase capacity..so thats another option also.
BiFfMaN is offline
