Shifting problems - Club700XX - Honda TRX700XX Forum
post #1 of 22 Old 05-17-2009, 06:21 PM Thread Starter
Shifting problems
Any of you guys having shifting problems? It seems like I am having trouble up shifting to second gear way more than I should be. Also having problems down shifting to first. It wants to hang up in neutral sometimes. Never had this problem on my 400ex. Or any other manual ATV/motorcycle/dirt bike for that matter. Any suggestions?
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #2 of 22 Old 05-17-2009, 06:55 PM
BiFfMaN's Avatar
Mine does the same thing, exactly like you describe. Once in neutral i just release the clutch and grab again, Falls right into first after that.
So with that being said..it could be that the Clutch is still grabbing just a bit. Maybe a cable adjustment is in order?
BiFfMaN is offline
post #3 of 22 Old 05-17-2009, 08:10 PM Thread Starter
I pretty sure the clutch is adjusted perfect. Like I said, I've never had this problem before with any other atv or motor cycle. Just this one. I guess it's pretty common with the xx.
post #4 of 22 Old 05-17-2009, 08:21 PM
BiFfMaN's Avatar
well two of us dont really count as common.
Unless anyone else wants to chime in?
BiFfMaN is offline
post #5 of 22 Old 05-17-2009, 09:31 PM
Chrisj's Avatar
Mine does it sometimes.
Chrisj is offline
post #6 of 22 Old 05-17-2009, 10:49 PM
Mine seems to skip neutral alot when i'm trying to get it in neutral. Gary said his did the same thing, then he tightened his chain and it went away. I didn't think my chain was loose though.
post #7 of 22 Old 05-18-2009, 02:08 AM
700xxx's Avatar
I hardly ever use the clutch except for taking off. I have always rode like that .is it hard on the trans to not use the clutch??
700xxx is offline
post #8 of 22 Old 05-18-2009, 09:31 AM
Yep. I don't know if the two are related, but honestly all I changed was the oil and tightened the chain (see my wrenching thread)
Before I had to have the engine running to get it into neutral or it was very,very hard to find. Now for some reason it goes in like butta.
post #9 of 22 Old 05-18-2009, 09:38 AM
double_0_xx's Avatar
Neatural is a royal PIA.. only 2 rides. Maybe the chain is loose from the factory?
double_0_xx is offline
post #10 of 22 Old 05-18-2009, 09:41 AM
IDK
I'm not saying that was what fixed it, only that mine magically started worked better.
