Exhaust Trouble - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 05-20-2009, 07:34 PM Thread Starter
08TRX700XX's Avatar
Send a message via AIM to 08TRX700XX
Exhaust Trouble
I just got back from my 2nd ride ever and looked at the pipe and it had changed colors on the end and looked like it got hot. So I took it apart and the end cap is fine but the piece that holds the packing in actually melted and then the packing must have started to blow out cuz its missing about half of it on the top section cuz the top bolts come out. Was wondering if anyone else was having any issues with them.
2008 TRX700XX Red/Black
Two Bro's Slip On
PC3
08TRX700XX is offline
post #2 of 6 Old 05-20-2009, 09:12 PM
post #3 of 6 Old 05-20-2009, 10:01 PM
TRX_Sixpac_700xx's Avatar
What are your juice box settings at? Do you have stock air filter? With stock juice box settings chances are you'll run a hair lean if anything. Velocity/K&N air filter will make it run leaner. Have you checked your plug?
TRX700XX
-UNI Air Filter
-2Bros Exhaust
-2 Bros Juice Box
-13T Sprocket
-Pro Armor Fat Pegs (Black)
TRX_Sixpac_700xx is offline
post #4 of 6 Old 05-21-2009, 07:23 AM Thread Starter
08TRX700XX's Avatar
Im not running the Juice Box anymore, I upgraded to a PC and this was the first ride with that. I pulled the plug and it dosent look that bad, Im running bo's map with the leaned out idle. Im not sure what happened.
Two Bro's Slip On
PC3
post #5 of 6 Old 05-28-2009, 01:24 PM
What type of silence are you using, the P3 or P1, if it's the P3 then it's causing too much back pressure which is then melting the packing, one of the 2Bros tech told me this.
post #6 of 6 Old 06-02-2009, 01:56 PM Thread Starter
08TRX700XX's Avatar
Im using whatever came in it just put it on and rode it
Two Bro's Slip On
PC3
