fmf tuning?? - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 05-27-2009, 01:19 AM Thread Starter
700xxx's Avatar
fmf tuning??
ok so I have k&n filter with an outer sock, a fmf powerbomb header, a factory4.1 muffler with a sparkarrester/quiet core and the fmf programmer it has 6 adjustments on it. I was wondering what others where running theres at for about sea level and about 3000 ft.?
700xxx is offline
post #2 of 12 Old 05-27-2009, 07:01 PM
i had the same basic set up and to tell you the trth i would go with a pciii as all the other guys are using.. it seemed to me like i couldnt get enough fuel to it i never did get the programer right and with only mabey two hours of road riding i was out of gas. to me that was to much gas bing used and i had beter luck with the stock filter an fmf pipe and no programmer bike runs great now. sorry i cant really help but it you figure it out please let me know.
hondarider203 is offline
post #3 of 12 Old 05-27-2009, 07:46 PM
The dobeck type controller has the problem that it can only add fuel but not send less fuel. The PC3 and PC5 can send more or less fuel. Also the PC3 can be finetuned a lot more than the dobeck since on the dobeck you can change idle, mid and WOT. But if you are on a tight budget the dobeck will help you to at least not be lean if properly tuned.
post #4 of 12 Old 05-27-2009, 08:58 PM Thread Starter
700xxx's Avatar
ya I figured I would get the "go with the pc3/pc5" thing but I dont have the budget right now so I have what I have. with the fmf I can adjust how much fuel and when it comes on at cruise,acceleration,and full throttle.so with that being said if the plug is white when cruising (no idle time )needs more fuel. I was kind of hoping some one could get me a little closer so I did not have to pull the spark plug out 900 times. I guess I will tell ya what I come up with.
700xxx is offline
post #5 of 12 Old 05-27-2009, 10:50 PM
700xx crazy's Avatar
Ur plug should be the color of cardboard ya know kinda light brown. Thats what ur lookin for IMO. Everybody has thier own! Hope this helps.
700XX CRAZY
HMF Ballance slip-on
PCIII w/"BO MAP"
Outerwear Lid Mod (by me)
Trail Tech Riser
Chub Bars
HONDA Bar Pad
RAZR2 Fronts
RAZR Rears
Elephant Ear Hand Guards(LOL)
700xx crazy is offline
post #6 of 12 Old 05-27-2009, 11:18 PM Thread Starter
700xxx's Avatar
ok so I burned my fingers several times but I came up with 3 for cruise,5.5for acceleration,5.5for WOT. set to come on at 3 for acc,3.5 for cruise and 3.5 for WOT. Im going to pick up some new plugs tommrow and play some more.
700xxx is offline
post #7 of 12 Old 05-28-2009, 08:51 AM
double_0_xx's Avatar
02 sensor would be awesome. Is this available in the pciV?
double_0_xx is offline
post #8 of 12 Old 05-28-2009, 08:57 AM
post #9 of 12 Old 05-28-2009, 12:23 PM
What is your exact filter setup? EHS lid? With this I can give you ballpark numbers to get you closer. From your mentioning 6 settings this must be a gen 3 controller, correcct?
post #10 of 12 Old 05-28-2009, 12:42 PM
Oh also forgot to comment about the altitude: The stock ecu will adjust for air temp and altitude changes via on board sensors, but being it does not have an O2 sensor it can not adjust for mods to the intake or exhaust etc.
