Vibration/Rattle in front of engine - Club700XX - Honda TRX700XX Forum
post #1 of 18 Old 05-27-2009, 04:20 PM Thread Starter
xx-rated's Avatar
Is anyone getting an annoying vibration/rattle in front of their engine? My XX developed one over this past weekend. It's not real bad, just annoying. It seems to do it the most when revving it up in first and second gear. It sounds like it up in front, maybe around the radiator.
xx-rated is offline
post #2 of 18 Old 05-27-2009, 06:25 PM
I had the same thing. It turned out to be the bolt that secures the over flow bottle to the frame and also the bolts holding my Pro Armor bumper. Not sure what one was making the noise, but it's stopped since tightening them.
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #3 of 18 Old 05-27-2009, 06:40 PM
Mine was the heat shield. Bolt fell out - I replaced it - no more rattle.
post #4 of 18 Old 05-27-2009, 06:52 PM
i had that as well turns out that my brannew dg front bumper mount cracked... this is horse s#!+
hondarider203 is offline
post #5 of 18 Old 05-27-2009, 07:50 PM
jj69's Avatar
Send a message via MSN to jj69
within the first month i had mine, all the plastcis in the front end had rattled loose and the shrouds for in front of the radiator are loose. i tightened everything up and theres still a noise.
08 700xx
12 F150
jj69 is offline
post #6 of 18 Old 05-27-2009, 07:53 PM
This is the only issue my friend has with his TRXis bolts loosening up... loctite as many screws&bolts as you have the patience to.
post #7 of 18 Old 05-28-2009, 02:14 AM
tomkat's Avatar
ya... my cap screws backed out... almost every one. loctite cures this problem. and i only thought of it after i lost 3... lol damn slow thinker
tomkat is offline
post #8 of 18 Old 05-28-2009, 08:18 AM
post #9 of 18 Old 05-28-2009, 04:46 PM
wv700xxrider's Avatar
my DG bumper broke the bottom bracket. It makes all kinds of noise.
wv700xxrider is offline
post #10 of 18 Old 06-04-2009, 07:14 AM
Killer_Shee's Avatar
I had the same problem after my last ride, and investigation showed that the welds on the lower mount on my Pro Armor bumper had broken completely loose. I see that even DG is having this problem. I am wondering if there isn't some flex in the frame that is causing this since it seems to be a problem with all the bumper and not just Pro Armor.
Killer_Shee is offline
