Rear end vibration /shakes at high speeds on pavement. - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 09-14-2013, 03:52 AM Thread Starter
Like the topic says. This was the first time I actually ran the quad on pavement. I just found it odd since my renegade doesn't shake at all on pavement.
10spoke is offline
post #2 of 9 Old 09-15-2013, 08:53 AM
Quoted: 242 Post(s)
Welcome to the club! I'd check the right axle for play in the inboard joint...
post #3 of 9 Old 09-22-2013, 07:39 PM
Quoted: 4 Post(s)
Hello and welcome to the forum, I would agree with M Quick check its inboard joints and some bushings that may need some replacement.
kartl is offline
post #4 of 9 Old 10-02-2013, 05:40 PM Thread Starter
How much play are we talking here? It moves but not much at all if any.
10spoke is offline
post #5 of 9 Old 10-02-2013, 06:02 PM
knobbie tires tend to vibrate on pavement
post #6 of 9 Old 10-02-2013, 06:46 PM Thread Starter
My renegade has zillas on it with no vibration. The xx has a set of RAZR. With sever vibration. I checked the lugs, tire pressure and all is good. When I ride I don't notice anything just on payment. Idk if it's something to worry about.
10spoke is offline
post #7 of 9 Old 10-02-2013, 07:20 PM
Quoted: 242 Post(s)
If it has play in it sitting still, imagine it at high speeds. How did you check the axle for play? If you grab the right axle and shake it, if there's any movement it's not good, imo. You can also jack rear off ground, and rock the rear tires in opposite directions. And look and see if the right axle near the brake rotor wobbles.
When my inboard joints started going out, I too noticed a vibration on the black top. Well not so much a vibration, but a up & down feeling in the rear end there was no noise...
post #8 of 9 Old 10-03-2013, 12:29 AM Thread Starter
Thanks!! Is this a pretty common problem? What can I do to prevent this from happening again?
10spoke is offline
post #9 of 9 Old 10-03-2013, 10:18 AM
Quoted: 242 Post(s)
As I recall tbird88, was the 1st to warn people of this issue. To prevent this you do what's called maintenance, that Honda chose to leave out of the owners manual! Anyway to prevent this, you need to remove the right axle from the rear carrier, and grease it.
