handlebar help - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 09-20-2013, 08:16 PM Thread Starter
IIIBuckIII's Avatar
handlebar help
hey guys iv searched the forum and didnt find what i was lookin for so ima ask. i have a 2008 and i want to raise my bars 2" and about a inch more of pullback i was lookin at the 7/8 protapers but what bend would i need.keep in mind on the 08 the bars are shorter then whats on a 09 and i dont want to change my cables out well they are on my 08 and my buddys 09se anyway
Prm Desert II bumper
Alba Pro Elite Nerfbars Silver/Black
Alba Gas Cap Red
DWT .190 with GBC XC-Master 22x7 Front
DWT .190 with GBC X-REX 20X11-10 Rear
EHS Air Lid
EHS Controller
BigGun EVO-R Full Exhaust
UNI Filter
Tusk 30mm Riser Extenders
IIIBuckIII is offline
post #2 of 3 Old 11-08-2013, 04:29 PM
woodsbike81's Avatar
Hey Buck, I'm running the 1 1/8" Trail Tech X-Bars (Windham bend) and a Trail Tech riser clamp. The Trail Tech offers the XX clamp in a low, medium and high version. I got the high. I'm 6-4" and the Windham bend bars w/ high clamp combo works well for me. This combo cured the bar vibration, some arm pump and the back ache issue while standing up to ride, which is most of the time for me. The TT bars are also wider which is great. No cable length issues either though any higher and there probably would be. The stock setup was horrible. Oh yeah, TT clamps only work with the stock stem. There's some stronger aftermarket stems and tie rods out there but I'd rather the softer stock units, instead of the frame, give during a crash. I speak from experience. I'm a hard core enduro rider and this set up has worked well for me. I also changed the stem, stem bushing, tie rods, ends, ball joints and cleaned/greased the A-arm bushings for some good preventive maintanance. Highly recommend the TT bars and clamp. Hope this helps.
woodsbike81 is offline
post #3 of 3 Old 11-08-2013, 04:30 PM
My bike's also an '08
