Front A-arm bearings.. - Club700XX - Honda TRX700XX Forum
post #1 of 37 Old 09-26-2013, 09:14 AM Thread Starter
How the hell are you meant to get the little metal clips out that hold the a-arm bearings in ??
rappey is offline
post #2 of 37 Old 09-26-2013, 06:09 PM
i never saw a clip i went back with all balls front a arm bushings and seals next time prolly pivot works they have the best warrany!
post #3 of 37 Old 09-26-2013, 07:51 PM
Quoted: 252 Post(s)
The stopper rings, should be able to just pop loose with a thin sharp flat blade screw driver.
post #4 of 37 Old 09-26-2013, 09:26 PM
Posted same question about 4 months ago and not a single answer . I learnt the hard way.
Chainsaw and WD40 did it for me.
post #5 of 37 Old 09-27-2013, 08:02 AM Thread Starter
Chainsaw ??? For those that have not come across it yet, its very similar to the snap ring that goes in the end of the gudgeon pin/piston pin/wrist pin, but that has a slot to get an implement in to pop out the snap ring.. The a-arms do not..they have a tiny slot but anything that fits in it will be so small that it will break...
Using a screwdriver on it just makes it spin round and round...
One person suggested drilling a tiny hole to poke something through to push it out.. dont really want to go down that road.
Its called a stopper ring in the workshop manual.
rappey is offline
post #6 of 37 Old 09-27-2013, 10:48 AM
Quoted: 252 Post(s)
Using a screwdriver on it just makes it spin round and round....
Can you not hold it still and then pop it out, hold it with one driver and pop out with the second.
post #7 of 37 Old 09-27-2013, 12:47 PM Thread Starter
No as there is no way of getting anything (that im aware of) in, around, down the side or under it...
Space is also very limited..
rappey is offline
post #8 of 37 Old 09-27-2013, 03:36 PM
Rappey, can you take a picture of it? Can send it to my email, [email protected] if you like. I am not on here much.
post #9 of 37 Old 09-27-2013, 05:19 PM
There not too bad to do ,once you get the "knack" of them.
Remove seals and collars . There is a small amount of play in the spacing of the clips to the bearing. I just push the bearing with a socket and a vice one way upto the other clip. Then there is enough room to push the clip in with a screwdriver and prise it out. Push the bearing from the other side and bingo. Simples.
post #10 of 37 Old 09-27-2013, 06:44 PM
Quoted: 252 Post(s)
So there you have it, from a chainsaw & Wd40 to simples....
