Please chime in. Debating 22/20 or 23/22 10in rim - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 11-09-2013, 04:52 PM Thread Starter
Please chime in and tell me what you think. I decided to get the 10 in rim and I am getting GBC xc master tires. I am ordering sometime this weekend or Monday morning. I ride mainly trails and the extra width is not a problem. I do ride a lot of rocky trails. Please till me which setup and your opinion why. Would love to hear from people that have the same setup. Looking for Pros and cons.
Thank you
soul-train is offline
post #2 of 10 Old 11-09-2013, 06:54 PM
Holdenkush's Avatar
If there is lots of rocks and whatnot I would want as much ground clearance as possible. That's my thinking anyway.
Holdenkush is offline
post #3 of 10 Old 11-09-2013, 08:00 PM
headscratch
in riding rocks ground clearance is a must.. do you fast rock ride or creep? that will answer the ? about 21 and 23 and 22 inch tyres just a creepin or goin fast ? grim reapers would prolly do the trick if you never get out of third get the x-master if you can stretch it out ..6 ply or better is a must for less sidewall puncture and tire puncture .
post #4 of 10 Old 11-10-2013, 01:51 PM Thread Starter
I ride over them at a moderate speed. All of the trails are not rocky. I have not had any problems with stock height and I heard 20 in tires on the 10 in rims is about .5 to 1in difference. But was told it help the body roll so I can use the stock sway bar when I am on the rocky trails. I guess I was wondering if the 23/22 setup have more body roll
post #5 of 10 Old 11-10-2013, 02:12 PM
thats a good setup as long as the 23 fronts dont rub your nerfbar or do you even have nerfs? if not 23 will be fine. i think they rub the factory honda nerfs,thats a good trail setup . i run 22-7-10 front and 22-10-10 rear and like it way better than oem
post #6 of 10 Old 11-10-2013, 03:00 PM Thread Starter
I don't have nerfs. Does the 22in rear have more body roll or does the extra width from the offset of the rears help? I was thinking 23 front since I don't have nerfs I heard it helps the turning to have a bigger tire in the front. If you didn't have nerfs would you have gone 23 front or still 22?
post #7 of 10 Old 11-10-2013, 03:10 PM
still would of went with 22 6ply and yes it turns way better with a 22 or 23 front 6 ply and the rear has less body roll with 6ply 10 or 11 inch rears
post #8 of 10 Old 11-10-2013, 03:13 PM
22/20 setup will be fine with you're kinda riding. It has less "body roll" than the 23/22. Never tried a 23/22 setup as the 700xx on 22/20 is about the same as most 4x4's I have raced against ground clearance wise. Also a 20x11x10 Klaw on a 10x8 [email protected] is the same height as a 22x9x11 Kutter on a 11x7 [email protected] I'll post a pic if you need it.
post #9 of 10 Old 11-10-2013, 10:23 PM Thread Starter
I would like to think everyone for their help. I ordered my tires and wheels tonight. I went with the 22/20 setup. I like the less body roll because I want to use the stock sway bar so I can take advantage of the IRS on some of the trails.
post #10 of 10 Old 11-11-2013, 07:57 PM
I have 23/22 and 21/20. Both are good but the 21/20 handles more precise. The 23/22 is better in the mud tho.
