Pro Taper Contour Question - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 07-02-2009, 01:38 PM Thread Starter
De700's Avatar
I am looking at switching my bars to the Pro Taper Contour and I am looking for anyone who could help with which model would be best in the contour series. I am having trouble figuring out what model I want ATV high, ATV mid, ATV low, etc....?
Also any insight into purchasing them or pref would also be appreciated.
Thanks,
CJ
De700 is offline
post #2 of 7 Old 07-07-2009, 05:49 PM
I don't know if pro-taper make them but I always fit Suzuki quadracer renthals ,It's quads equivilant to CR-HI on 2 wheelers. I would check the measurements of these on Renthals website and compare to Pro- Tapers measurements.Hope this helps.
post #3 of 7 Old 07-07-2009, 05:59 PM
xx-rated's Avatar
I have the Pro Taper EVO in the CR Hi bend. With the Trail Tech logo clamp they are about stock height.
xx-rated is offline
post #4 of 7 Old 07-08-2009, 05:50 PM Thread Starter
De700's Avatar
Thanks
I sat down and measured the stock bars and found that the closest match was the Pro Taper contour raptor. I have it on order with a trail tech clamp.
Thanks
De700 is offline
post #5 of 7 Old 07-08-2009, 06:16 PM
i bought the pro taper clamps and and the handle bars are pro tapers too,they are the atv high bend they are a little bit taller than stock,and the bar pad inthe midle makes tah bike look killer.i tried posting pictures of it but dont know how.can anybody tell me how?im not that much of a computer wizz.
hector700 is offline
post #6 of 7 Old 07-09-2009, 01:30 AM
I like the cr high bend that's what I've road on a lot of 450r and it feels good. That's what I'll be getting
post #7 of 7 Old 07-10-2009, 08:59 AM
xx-rated's Avatar
You'll be very pleased with the difference a good set of bars make. That was the first mod I did. The stock bars seem like they belong on a tri-cycle!
xx-rated is offline
