thinking about bear claws front and rear - Club700XX - Honda TRX700XX Forum
post #1 of 34 Old 01-02-2014, 04:24 PM Thread Starter
thinking about bear klaws front and rear
I have been doing mostly woods riding and love the xx's capability. The stock tires are holding me back. I was going to order cutters and came across a bear claw thread here. With that being said, does anyone have 23x7x10 front and 23x8x11 rear. Anyone have this setup. I hate the front end push this bike has and would like to get something that grips nice. I know it will give the xx more of a utility look but how will it handle. thanks guys
Motojoe is offline
post #2 of 34 Old 01-02-2014, 05:01 PM
Quoted: 242 Post(s)
the l8ton sway bar will cure the push.
post #3 of 34 Old 01-02-2014, 05:14 PM Thread Starter
I did the biggest sway bar. Made a huge difference but I still feel the front slide around. My 450r was very planted. As soon as you hit the gas on the xx while turning the front looses bite. Everyone says tires help.
Motojoe is offline
post #4 of 34 Old 01-02-2014, 05:18 PM
Quoted: 242 Post(s)
Yea tires help, your body language play's a big role as well. If your on the gas and raising the front end, well with no weight on even the best tire available it wont grip.
post #5 of 34 Old 01-02-2014, 05:20 PM
Tires do help, ED's uppers make a world of difference IMO too.
post #6 of 34 Old 01-02-2014, 05:49 PM
grin
the kutter fronts cured my front end push the oem sidewall is flimsy and flexes during slow hard turns the 6 ply stays more planted and you turn on a dime compared to the oem ,bearlaws are more of a utility quad tire and will make your steering even harder compared to a tire that should go on the xx which is a knobby type tire not tractor tire pattern bearklaws are prolly lighter than zillas which the honda ute guys like zillas better because they are one of the lightest mud tire and the price is way better than the rest of the so called mud tires which all of them have a tractor type pattern or chevron pattern
post #7 of 34 Old 01-03-2014, 07:31 AM
Snoshoe's Avatar
You have prob seen my thread already. ive got the 23x8x11s they have a thiner contact patch so I tend to dig a little deeper. I am 240lbs and still have the stock fronts with maybe 1/4" in the knobbies, ridding around the ranch is mostly lawn and pasture so I really don't have a problem with the push. I do have to make wider turns on the lawn to limit the destruction. The problem isnt so bad with my wifes forman and stock tires. I would only think you'ld need the same tread on the front is for looks or if you had 4 wheel drive. just my $.02
2008 TRX700xx
13Tfront
Kenda Bear Claws 23x8x11
Custom 2" receiver
rear seat/ strorage box
Ground Hog Disk harrow kit
PEI fog lights
Snoshoe is offline
post #8 of 34 Old 01-03-2014, 02:36 PM
Holdenkush's Avatar
Hey there I run a set of zillas in the back. They are an awesome tire they are 24-10-11 and they pull hard in all conditions. Very durable so far. Have OEM sized razrs in the front. It's a good setup. The razrs help eliminate most if the push up front. Maybe try some suspension adjustments to keep more weight down in the front help the tires grip a bit better. Maybe. I checked out bearclaws and preferred the zillas for the tread and weight. If I could change anything I'd bump up the size of the front tire a bit to maybe a 22 or 23. The bike has a definite forward lean now. But that also helps keep weight on the front end in the corners. But that lean may have also caused my bike to do a front flip when I hit a hole. As opposed to staying flatter and potentially riding it out. Jmo.
Holdenkush is offline
post #9 of 34 Old 01-04-2014, 02:06 AM Thread Starter
Hey snoshoe, is the 23/8/11 much thinner than the stock tire. Compared to the stock tire does it seem much taller? Skinnier? And do you plan on getting them upfront soon?
Motojoe is offline
post #10 of 34 Old 01-04-2014, 10:33 AM
Quoted: 242 Post(s)
You should try adjusting your front pre-load to raise the front up. The front of the quad should be slightly taller than the rear. This may be hard to do with 24's in the rear and 21's up front, but I'd crank that pre-load all the way, and see what it looks like.
