Ordering tires and rear rims - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 01-09-2014, 07:27 PM Thread Starter
whynot's Avatar
Hey guy's am about to order some GBC Xrex 20x11-10 for the rear 2 of them for 168.00 and putting them on dougless .190 rims and was going to get some
link to the rears
http://www.ebay.com/itm/20x11-10-GBC...eddbcd&vxp=mtr
and going to get some GBC xc master 21x7-10 for the fronts on stock rims here is the link
http://www.ebay.com/itm/21x7-10-GBC-...b2385c&vxp=mtr
what do you think of the prices and how is this set up. thanks in advance
mike
whynot is offline
post #2 of 11 Old 01-10-2014, 12:28 PM
Make sure you get the right off set rear rims. I'm in the same boat is you. The back of the quad will be 51" wide minimum even with the correct offset rim.
Motojoe is offline
post #3 of 11 Old 01-10-2014, 05:32 PM Thread Starter
whynot's Avatar
motojoe, I ordered this setup last night, I think with the xtra ground clearance and then going with the 20" rears and 21" fronts and it being a lil wider it should feel more stable going into a turn and getting on it. I will add the aftermarket sway bar soon also. and no need for the 13t front sprocket with the 20" rears..
whynot is offline
post #4 of 11 Old 01-10-2014, 06:03 PM
I ran a similar setup . Front will be about 47" and rear a tad over 50". It does pretty good but if you ride it only heavily rutted corners or berms it tries to ride straight over them.
post #5 of 11 Old 01-10-2014, 06:55 PM
Quoted: 252 Post(s)
whynot,
Did you not see my link to purchase these tires? You could of saved close to a hundred dollars here...
https://www.costco.com/webapp/wcs/st...=gbx+xc+master
Plus they stopped making the X-rex awhile back???
I guess you had to see my old info on tires. I was bored so I dug this thread up..
https://www.club700xx.com/vb/showthre...t=costco+tires
M_Quick is online now
post #6 of 11 Old 01-10-2014, 08:13 PM Thread Starter
whynot's Avatar
M_Quick Yes I did I look around on here and found ur link and bought them from costco. thank you very much for posting the info and sharing all 4 tires came out to be $209 plus tax and non member fee $237. I ordered the rear rims from rockmountain
whynot is offline
post #7 of 11 Old 01-11-2014, 04:31 PM
Quoted: 252 Post(s)
Cool, I seen the above links and just thought you order'd from them.
post #8 of 11 Old 01-15-2014, 06:03 AM Thread Starter
whynot's Avatar
going to get these mounted today yaaa lol so my rear will be about 50" wide how wide should my front be? is there a standard people usually follow? I am thinking of getting some spacers to widen it..
whynot is offline
post #9 of 11 Old 01-15-2014, 03:52 PM
Quoted: 252 Post(s)
So far I've just left mine alone. I wish I didn't have the $ I have tied up in shocks. If I was to do it again I would get longer a-arms, and shocks to match. IDT my Elka's would work with a +2" arm.
post #10 of 11 Old 01-15-2014, 04:58 PM
you can get a 3-2 offset front rims instead of spacers, with your 4-3 rear 10 inch wheel it will almost make it as wide as the back,it works good for me.
