Tie rods - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 01-20-2014, 10:16 PM Thread Starter
jdkboxer's Avatar
Tie rods
I just noticed my Tie rod on the left front is bent. Should I just replace the tie rod, or replace the ball joints as well. The ball joints on it are in good shape. It just the tie rod bent. Any suggestions will be helpful!
jdkboxer is offline
post #2 of 5 Old 01-21-2014, 08:29 AM
Quoted: 5 Post(s)
Yes just the tie rod
Elmer is offline
post #3 of 5 Old 01-21-2014, 04:19 PM
just the tierod but if you dont get the camber or castor adjusted right it will pull to one side
post #4 of 5 Old 01-21-2014, 04:39 PM
Quoted: 248 Post(s)
The ball joints as you call it, are what I refer to as tie-rod ends. I'm not so sure we can even replace our ball joints with out ordering a-arms...? When I bent a tie rod, I was contemplating over going back oem or after market. And was talked into going oem, so I could keep the weak link so to say.
post #5 of 5 Old 01-21-2014, 05:35 PM Thread Starter
jdkboxer's Avatar
Thanks for the help! I ordered just the tie rod today! Im going to give it a shot and see what happens.
jdkboxer is offline
