Same size tire at all 4 corners? - Club700XX - Honda TRX700XX Forum
post #1 of 23 Old 02-05-2014, 06:54 PM Thread Starter
Quoted: 33 Post(s)
I am thinking of running 22x7x10 Kenda Kutter XC's on Hiper 10x5 4-1 offset rims at all 4 corners. I have 3 out 4 tires and still would need to purchase the rims.
Does anyone see any issues with doing this?
Luecker is offline
post #2 of 23 Old 02-06-2014, 11:55 AM
some of those guys that run them rally races use a setup similiar to that. i dont know though 7 wide in the back seems narrow to me but i dont know i never tried it!
post #3 of 23 Old 02-06-2014, 02:55 PM
whynot's Avatar
Why would you even want to run it that way? it would look weird lol prob handle like crap
whynot is offline
post #4 of 23 Old 02-06-2014, 06:25 PM
Jmm24's Avatar
I've seen a few desert racers running that setup but it would probably be horrible for trails.
Jmm24 is offline
post #5 of 23 Old 02-06-2014, 07:37 PM Thread Starter
Quoted: 33 Post(s)
I have 3 tires and 4 stock front rims, so for right now I am going to buy 1 more tire and test it out. If it works I will drop the $$ on the hipers.
Only thing that concerns me is the profile of the tire changes. I was looking at the xc masters but I would have to cut knobs off to get rid of the continuous center rib.
Luecker is offline
post #6 of 23 Old 02-07-2014, 11:21 AM
Quoted: 242 Post(s)
The xc racer that posted on here awhile back had 22x8x10 tires on all 4 corners. I think they were 22 high? I asked him a similar question, and his answer was in case of a flat. He'd only have to have one type of spare instead of two. I two think it looked funny, and don't see how it could handle well in the turns. But he was xc not mx...
post #7 of 23 Old 02-07-2014, 02:41 PM
I know if at least one desert racer 700XX that has run front tires on all four corners, but that 700XX custom framed/suspended. Seemed to work alright. I think cornering would be fine, I would be more concerned about forward bite. If you already have the stock wheels and three of the four tires, I say buy another tire and try it. let us know how it works.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #8 of 23 Old 02-07-2014, 03:10 PM
In order for you to do that, wouldn't you need different hubs in the rear because the bolt pattern is different between the fronts and the rears on this machine? I could be mistaken, having so many darn toys I can't keep it start. It'd be as simple as changing out the rear hubs w/ some rancher ones as some of the guys have done on here. I guess I'd just make sure the clearance is there as well with the rear A Arms, which I imagaine it shouldn't be a problem if they are front wheels.
post #9 of 23 Old 02-07-2014, 04:35 PM
Quoted: 242 Post(s)
The fronts and rears are 4/144, pretty sure of this.
post #10 of 23 Old 02-07-2014, 05:19 PM
You are correct.
Front wheels fit fine on the rear. I had a set of fronts on the rear of my one 700XX because I needed all the rear tires I owned for a race. Still wanted to be able to move that 700XX around the garage if I needed to.
Doug
2005 TRX450R
1986 TRX250R
