New trx700xx owner. Tire help - Club700XX - Honda TRX700XX Forum
post #1 of 14 Old 02-15-2014, 06:31 PM Thread Starter
Hey just picked up an 08 xx today looking to put a wider tire on the stock rim what is the widest I can fit on there and what should my first upgrades be exhaust etc. help me out please
Kjk240240 is offline
post #2 of 14 Old 02-15-2014, 06:40 PM
Holdenkush's Avatar
First mod should be tires the stock tires are poop. There aren't a lot of options in the 11" rear. There are maxxis razrs, kenda kutters, maxxis zillas, kenda bearclaws , and itp mud lites, and carlisle 489's are the ones I can think of off the top of my head. I've got kutters in stock size and zillas in a 24-10-11 size. I'm sure you may be able to get 11" wide to fit but the may rub on the shock I guess depends on the tires true size. Hope this helps as I spent many hours deciding which tires to go with. And I'm very happy with both pairs the kutters are awesome and the zillas rip hard on the xx.
Holdenkush is offline
post #3 of 14 Old 02-15-2014, 06:50 PM Thread Starter
Holden first thank you, what are you running in the back and what's the size
post #4 of 14 Old 02-15-2014, 06:55 PM
Holdenkush's Avatar
I'm running a set of kenda kutters in OEM size 22-9-11. And I've got a pair of maxxis zillas on the xx right now and they are24-10-11 and not a problem. And I'm running maxxis razrs in the front in stock size 21-7-10
post #5 of 14 Old 02-15-2014, 09:02 PM
Quoted: 242 Post(s)
I have a winter/mud set of 25x12.5x11 Bear Claws. They only rub the heel guards a touch, during high speed turns. I'd suggest the Razr 22x10x11's around $116 each. Or if width isnt a problem alot of people go with a 10" rear rim to open up your options on rear tires. You can get the douglas 0.190 wheels around $60.00 each and then go with GBC XC-Master 22x11x10's for around $67.00 each...So a few more dollars up front, but you getting a lot better wheel than the oem, and same quality tire imo...But quad will be around 5" wider in the rear.
post #6 of 14 Old 02-16-2014, 01:26 AM
IIIBuckIII's Avatar
you can go to 10 inch wheels like i did to make it wider im runnint a 20x11-10 thats about as wide as you can go without putting new hubs on there pluse with the 10s youll have more tire options
Prm Desert II bumper
Alba Pro Elite Nerfbars Silver/Black
Alba Gas Cap Red
DWT .190 with GBC XC-Master 22x7 Front
DWT .190 with GBC X-REX 20X11-10 Rear
EHS Air Lid
EHS Controller
BigGun EVO-R Full Exhaust
UNI Filter
Tusk 30mm Riser Extenders
IIIBuckIII is offline
post #7 of 14 Old 02-16-2014, 07:27 PM Thread Starter
So if I go with the Douglas what offset do I need or what is the bolt pattern. Thanks for all the input width doesn't bother me
post #8 of 14 Old 02-17-2014, 12:28 PM
Snoshoe's Avatar
bolt pattern is 4x144, stock offset is 5+2, tough to find that one in anything other than 11" other wise guys use a 4+3 for an inch wider stance
2008 TRX700xx
13Tfront
Kenda Bear Claws 23x8x11
Custom 2" receiver
rear seat/ strorage box
Ground Hog Disk harrow kit
PEI fog lights
Snoshoe is offline
post #9 of 14 Old 02-17-2014, 02:00 PM
Quoted: 242 Post(s)
The 5x2 in a 10" wheel wouldn't clear the rear A-Arm, thats why they make them 4x3 I believe.
post #10 of 14 Old 02-17-2014, 02:04 PM
Quoted: 242 Post(s)
4/144 Douglas .190 Wheel 10X7 4.0 + 3.0 $59.99 at
http://www.rockymountainatvmc.com/
Someone on here possibly whynot, just went with these and may be interested in selling, to go back to 11"???
https://www.club700xx.com/vb/showthread.php?t=12657
